Is the Android App crap for everyone or just me? I have Volumio installed on 3 different models of Raspbery pi’s in my house. Mainly I use them for Spotify connect for which I have the plugin installed in Volumio. This works great but I also like to use Volumio for web radio and for this I need to access Volumio. The app is pretty much unusable. When it does work its painfully slow but for the most part it just locks up and does nothing.
I can access the gui on each device using a my laptop by entering the IP address into a web browser. This works pretty well but its not a convenient solution. At least I know it’s the app at fault though as it works fine on a laptop…
Can anything be done to make the android app work better?
