I would like to use my Volumio setup at work. I have a RTL-8192cu USB adaptor, which should be adequate, but I’m only presented with options for WPA2 personal and WEP.
I have a script that will connect me to the network. How do I make it persistent.
you can change the settings for lan and wlan here: /etc/network/interfaces
what script do you have?
Can you provide some detail as to how you did this?
Been messing with this but it doesn’t seem like wpa_supplicant runs as part of the Volumio RPi image.
