Volumio Information
Volumio Version: 3 beta
Hardware: RPI4
DAC: hifiberry dac2
Hello everybody,
I am stuck on one thing for many days and its making me crazy. Iam trying to set up volumio with pulseeffects equalization but i am unsucessfull.
First i need to point out that i cannot use other solutions like equalizer plugin or hadrware equalizer because i really need bass enhancer and other enhancements present only in pulseeffects (or viper4linux but its certain libraries are not ported for ARM - i discussed that with creator of viper4linux)
Therefore i started my research. I installed classic Debian buster with gui and then pulseeffects itself - all working very nicely. Then with finished preset for equalizer i started moving this equalization with pulseeffect to volumio. I had some issues like absence of gui - i installed XVFB to launch it without it, then there vere some errors from GTK which i solved by
> $ sudo sh # umask 022 # update-mime-database /usr/share/mime # exit
which i have no idea what it does but after that pulseeffects launches just fine, i was able to put my equalizer preset to respective folder (output) and other file to folder (autoload) but equalization didnt happened. I then checked with pacmd that pulseaudio dont see any cards that are connected to system. I was a bit lost, added volumio user to audio and pulse group, tried to launch it as sudo, nothing worked.
Then i decied to uninstall pulseaudio and install it again because someone on forum said it helped him from unknown reason. After that i am able to see my cards finally but there is no “sink-input” when i play music over volumio. On normal debian buster with gui, when i play something on youtube for example and i let pacmd to list sink inputs it shows “chromium sink input” or something like that and it will capture it somehow and equalize the sound and then output it to sound card. But this is not happening in volumio, no input sinks shows up no metter how i play things in volumio - web radio, local files, airplay - nothing shows in pacmd, therefore its not capturing this stream properly and equalization does not happen.
I researched official documentation of pulseaudio but they only say this:
Note: If
pacmdreports0 sink input(s), double-check that the application is playing audio. If it is still absent, verify that other applications show up as sink inputs.
But nothing else, and in Volumio, volumio is the only app that is sending sound.
There is few outputs if it would help:
aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
Subdevices: 1/1
PACMD INFO
>>> info
Memory blocks currently allocated: 1, size: 64.0 KiB.
Memory blocks allocated during the whole lifetime: 1310, size: 2.7 MiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 0 B.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.platform-bcm2835_audio.analog-stereo
Default source name: alsa_output.platform-bcm2835_audio.analog-stereo.monitor
Memory blocks of type POOL: 1 allocated/1 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/1309 accumulated.
Memory blocks of type IMPORTED: 0 allocated/0 accumulated.
22 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "12.2"
index: 1
argument: <restore_device=false>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <tsched=0>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="0" name="platform-bcm2835_audio" card_name="alsa_card.platform-bcm2835_audio" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <device_id="1" name="platform-bcm2835_audio" card_name="alsa_card.platform-bcm2835_audio" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 8
argument: <device_id="2" name="platform-soc_sound" card_name="alsa_card.platform-soc_sound" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
index: 9
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
index: 12
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 14
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 25
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
3 sink(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY FLAT_VOLUME
state: SUSPENDED
suspend cause: IDLE
priority: 9000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
fixed latency: 59.95 ms
card: 0 <alsa_card.platform-bcm2835_audio>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "bcm2835 HDMI 1"
alsa.id = "bcm2835 HDMI 1"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "bcm2835 HDMI 1"
alsa.long_card_name = "bcm2835 HDMI 1"
alsa.driver_name = "snd_bcm2835"
device.bus_path = "platform-bcm2835_audio"
sysfs.path = "/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card0"
device.form_factor = "internal"
device.string = "hw:0"
device.buffering.buffer_size = "10576"
device.buffering.fragment_size = "2640"
device.access_mode = "mmap"
device.profile.name = "digital-stereo"
device.profile.description = "Digital Stereo"
device.description = "Built-in Audio Digital Stereo"
alsa.mixer_name = "Broadcom Mixer"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card"
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "video-display"
active port: <hdmi-output-0>
* index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 9009
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
Stereo
used by: 0
linked by: 0
card: 1 <alsa_card.platform-bcm2835_audio.2>
module: 7
properties:
device.api = "alsa"
alsa.name = "bcm2835 Headphones"
alsa.id = "bcm2835 Headphones"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "bcm2835 Headphones"
alsa.long_card_name = "bcm2835 Headphones"
sysfs.path = "/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card1"
device.string = "hw:1"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output>
index: 2
flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY FLAT_VOLUME
state: SUSPENDED
suspend cause: IDLE
priority: 9000
volume: front-left: 25545 / 39% / -24.55 dB, front-right: 25545 / 39% / -24.55 dB
balance 0.00
base volume: 56102 / 86% / -4.05 dB
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 2
Stereo
used by: 0
linked by: 0
card: 2 <alsa_card.platform-soc_sound>
module: 8
properties:
device.api = "alsa"
alsa.name = "HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0"
alsa.id = "HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "snd_rpi_hifiberry_dacplus"
alsa.long_card_name = "snd_rpi_hifiberry_dacplus"
alsa.driver_name = "snd_soc_hifiberry_dacplus"
device.bus_path = "platform-soc:sound"
sysfs.path = "/devices/platform/soc/soc:sound/sound/card2"
device.string = "hw:2"
device.buffering.fragment_size = "2644"
device.profile.name = "stereo-fallback"
device.profile.description = "Stereo"
device.description = "Built-in Audio Stereo"
ports:
analog-output-headphones: Headphones (priority 9000, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-headphones"
active port: <analog-output-headphones>
3 source(s) available.
index: 0
flags: DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 6
properties:
device.description = "Monitor of Built-in Audio Digital Stereo"
device.class = "monitor"
alsa.card = "0"
device.string = "0"
* index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 1
module: 7
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
alsa.card = "1"
device.string = "1"
index: 2
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 2
module: 8
properties:
device.description = "Monitor of Built-in Audio Stereo"
alsa.card = "2"
device.string = "2"
2 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 16
properties:
application.name = "Login Session 1"
systemd-login.session = "1"
index: 4
driver: <cli.c>
owner module: 25
properties:
application.name = "UNIX socket client"
3 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "0"
device.string = "0"
device.description = "Built-in Audio"
profiles:
output:digital-stereo: Digital Stereo Output (priority 5100, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:digital-stereo>
sinks:
alsa_output.platform-bcm2835_audio.digital-stereo/#0: Built-in Audio Digital Stereo
sources:
alsa_output.platform-bcm2835_audio.digital-stereo.monitor/#0: Monitor of Built-in Audio Digital Stereo
ports:
properties:
index: 1
owner module: 7
properties:
alsa.card = "1"
device.string = "1"
profiles:
output:analog-stereo: Analog Stereo Output (priority 5100, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.platform-bcm2835_audio.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.platform-bcm2835_audio.analog-stereo.monitor/#1: Monitor of Built-in Audio Analog Stereo
ports:
properties:
index: 2
owner module: 8
properties:
alsa.card = "2"
device.string = "2"
profiles:
output:stereo-fallback: Stereo Output (priority 5100, available: unknown)
output:multichannel-output: Multichannel Output (priority 100, available: unknown)
active profile: <output:stereo-fallback>
sinks:
alsa_output.platform-soc_sound.stereo-fallback/#2: Built-in Audio Stereo
sources:
alsa_output.platform-soc_sound.stereo-fallback.monitor/#2: Monitor of Built-in Audio Stereo
ports:
properties:
multichannel-output: Multichannel Output (priority 0, latency offset 0 usec, available: unknown)
properties:
0 sink input(s) available.
0 source output(s) available.
0 cache entrie(s) available.
And when i play something, it still says 0 sink inputs available
Iam launching pulseeffects manually and everytime its giving me these errors but it is running, not sure if it is related:
(pulseeffects:1088): pulseeffects-**WARNING** **: 08:12:24.139: pulse_manager: Pulseaudio 12.2 does not support norewinds. Loading the sink the old way. Changing apps volume will cause cracklings
(pulseeffects:1163): GLib-GObject-**WARNING** **: 08:14:12.111: g_object_set_is_valid_property: object class 'GstPulseSrc' has no property named 'D\xac'
I wasnt been able to found on the whole internet what the hell is “norewinds” and what loading sink old way means, nothing.
Is there anybody who knows pulseaudio and volumio and is able to help me? Please. Thank you
So i changed audio backend from ALSA to PA, then i defined output device as “default” and voilá, shairport output is grabbed by pulseeffects, equalized and then played, which is great. So it seems that “ALSA” backend somehow requires to be pointed on real hardware sound card and if not, then it refuses to send audio. But “PA” backend is probably accepting anything, even virtual cards, as outputs. Now the question is if something like this can be switched/defined in Volumio, so the Volumio wont be necessarily requiring physical hardware sound card as output and will be sending sound to pulseaudio rather. Did you guys have experiences with anything similar?
