I have been using succesfully the previous version of Volumio with my FiiO E10 OLYMPUS DAC (on Raspberry PI).
I have now installed the last version of Volumio (volumio-2.031-2016-11-23-pi.img).
The DAC is not recognised. In Playback options if I try to select USB:audio for Output Device it revert to “Audio jack”.
No problem instead with an Asus Sonar U3.
Any hint?
I am able to get the DAC working (as per michaelangelo’s suggestion) via
select “USB: Audio” in Playback Options -> Output Device
Hit save (instantly refreshes to “Audio jack”)
Reboot
Still says “Audio” (not even “Audio Jack”; that’s only visible when you expand the dropdown)
DAC works though
Volumio version: 2.041 on raspberry pi 3 model b
DAC: Fiio Olympus 2-E10K
[ 4.210454] usb 1-1.3: New USB device found, idVendor=1852, idProduct=7022
[ 4.218309] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.226545] usb 1-1.3: Product: DigiHug USB Audio
[ 4.232091] usb 1-1.3: Manufacturer: FiiO
[ 4.250753] input: FiiO DigiHug USB Audio as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1852:7022.0001/input/input0
[ 4.323842] hid-generic 0003:1852:7022.0001: input,hidraw0: USB HID v1.00 Device [FiiO DigiHug USB Audio] on usb-3f980000.usb-1.3/input0
Just in case it’s of any use to demo what I see, screenshots attached. Audio here refers to “Audio Jack”, which should be standard for all Pis, right? USB audio is what I’d really want to select
Default display
Dropdown selected.
If there’s any more useful logs I could grab from it all, let me know, happy to help. Or equally could file a bug report if it’d help?
Thanks!
