New Volumio User with RPi3, Allo Kali, Piano Dac v.1.0, Rasberry Pi 7" screen who is struggling with couple of things. I have attempted to search and read through some of the FAQ but I did not find anything that helped answer my question, so posting a new thread about it. I am pretty sure that I am doing something stupid and missing a configuration setting to address the issue. I am using the free version of MyVolumio, in case that makes a difference.
- I plan to use Spotify via Spotify Connect (multiple folks in the household will be using it) and Apple Music via Airplay. Under both I can connect and stream without any issues but neither of them show the album cover of the song currently playing. If I start Spotify from withing Volumio it shows the album cover.
- How do I configure Volumio to show the correct bitrate. For example, Apple Music is saying it’s 24-bit/48kHz ALAC but Volumio is show it as 44.1/16bit. Is Airplay restricted to 16-bit/44.1kHz? Streaming Apple Music Lossless is one of the goals.
- Trying to enable SSH via http://volumio.local/dev screen but I always get “Connection reset by ipaddress port 22” when trying to connect. I do not see an option to save the settings under “Enable SSH”
1 and 2 are critical, I can leave without the SSH access.
Thank You
