it would be nice, if i can control my Volumio PI via Touchscreen. adafruit.com/products/2097
Im new here and look for some inforamtions about Tochscreen Development. Or are there some Projects to control Volumio with a Adafruit Display?
Regard
Noxx,
Take a look at this project “Tron radio”. It is based on mpd/mpc so you can use it with Volumio.
Blog http://5volt-junkie.net/raspberry-pi-internetradio/
Github: https://github.com/5Volt-Junkie/RPi-Tron-Radio
Forum: http://www.forum-raspberrypi.de/Thread-rpi-tron-radio-raspberry-pi-webradio-im-tronstyle …some updated versions with extra features
Regards
Harry
i read this, but it is not the same as volumio.
i had read some other pages, but the infos that i found isnt good: volumio isnt perfect for touchscreens. perhaps with the next version, v1.5 dont support this.
