Is it possible to use just boom DAC Hat and Justboom AMP Hat with the display? It looks like it utilises power through the GPIO pins. If so could i either connect standalone Hats or solder the display wires to the other side of the header pins (GPIO)?
I’m running Volumio on a Pi 3 and the standard 7" display. The Smart Pi touch case I put it in came with a usb splitter so the Pi and display can both be powered by the external power supply. For audio output I use a Justboom Digi HAT. This hardware and the latest Volumio version worked first time right out of the box.
Sounds pretty close to what you are asking, hope this helps.
