I’m running Volumio 4 on a Raspberry Pi 4, and recently I noticed that the new/available plugins are no longer showing up in the plugin store. I can still see the plugins that are already installed, but I cannot browse the full list of available plugins.
This started happening around the time I accessed the /dev page in the Volumio interface to enable SSH. I’m not sure if the two things are related.
I managed to get Glass installed and working on my system.
My setup is Volumio 4 running on a Raspberry Pi 4 Model B (armv7l, Raspbian GNU/Linux 12 Bookworm).
The installation initially failed with the error:
Could not detect the Volumio architecture
I investigated the Glass installer and found that it reads VOLUMIO_ARCH and VOLUMIO_VARIANT from /etc/os-release.
To resolve the issue, I added the following entries to /usr/lib/os-release:
VOLUMIO_VARIANT="volumio"
VOLUMIO_ARCH="arm"
After that, I reran the Glass installer, and Glass was successfully installed and enabled. The visualizer is now working correctly.
I also created a backup of the original /usr/lib/os-release file before making the changes.
I have not yet determined why these values were missing in the first place. Do you recommend any further checks to identify the underlying cause, given that everything is now working?
Glad it runs. Two things before you close the case.
Half identified. Your two lines satisfy Glass. Volumio still misses VOLUMIO_VERSION, VOLUMIO_HARDWARE and VOLUMIO_HASH, which its plugin manager and updater need, so plugin installs and the update check may misbehave or quietly pass you by.
The suspect./usr/lib/os-release belongs to Debian’s base-files package; an apt upgrade that brings a new one writes it without Volumio’s lines - and would take your hand-written ones with it next time. The one history that survives a reboot on a Volumio player is the volumio user’s:
