Volumio 4 - can't see SSD partition
I’m running Volumio 4 with RPi5, nvme 2TB SSD, external Topping DAC.
Can’t seem to save my music onto the SSD…
lsblk shows…
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 692.8M 0 loop /static
mmcblk0 179:0 0 59.4G 0 disk
|-mmcblk0p1 179:1 0 366M 0 part /boot
|-mmcblk0p2 179:2 0 4G 0 part /imgpart
-mmcblk0p3 179:3 0 55.1G 0 part nvme0n1 259:0 0 1.9T 0 disk |-nvme0n1p1 259:1 0 366M 0 part |-nvme0n1p2 259:2 0 4G 0 part -nvme0n1p3 259:3 0 1.9T 0 part /data/INTERNAL
/data/INTERNAL
But in Volumio Music Library view there is no SSD - INTERNAL, NAS, USB only.
Saving to INTERNAL saves to 4GB mmcblk0p2 partition NOT 1.9TB nvme0n1p3 partition.
How can I save to nvme0n1p3 ??
Hey @Bigguy2018,
Can you elaborate your requirement a little bit more please?
From the details you provided, you are currently booting from a microSD card. Is this where you want to see a single NVMe storage partition to be visible?
However, if your aim is to boot from NVMe, then use the “Install to Disk” tool found in System (this option is available when booted from microSD), and boot from NVMe once the microSD card is removed.
Not the boot order - I want to store my music on the NVMe partition.
Previosly I accessed \192.168.0.66\Internal Storage (from Win PC) and copied tracks across to the SSD.
Now doing so copies to the SD card.
Hey @Bigguy2018,
The method isn’t complex.
In a nutshell - you need a single partition labelled “issd”. rest - enjoy the magic!
OK, I’ve got a partition labelled issd
lsblk -f
NAME    FSTYPE FSVER LABEL    UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0   squash 4.0                                                       0   100% /static
mmcblk0
|-mmcblk0p1
|       vfat   FAT32 boot     EFEC-2342                             273.6M    25% /boot
|-mmcblk0p2
|       ext4   1.0   volumio  cafa11af-4043-4b82-b2f1-cf9789a0d0ff    2.9G    20% /imgpart
`-mmcblk0p3
        ext4   1.0   volumio_data
                              3bba9da0-7f1b-4d9e-aef5-c0cdf6d74a8c
nvme0n1
|-nvme0n1p1
|       vfat   FAT32 boot     BD49-965D
|-nvme0n1p2
|       ext4   1.0   volumio  9c8277da-dca0-440f-9fd2-13af79d0ef7c
`-nvme0n1p3
        ext4   1.0   issd     a1ffdbd1-a589-405f-834f-933004969182    1.7T     0% /data/INTERNAL
        /data/INTERNAL
sudo blkid
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="EFEC-2342" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="6606bc33-01"
/dev/nvme0n1p3: LABEL="issd" UUID="a1ffdbd1-a589-405f-834f-933004969182" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="2fbd2c8c-02c8-49f5-9f81-66383fbc9d57"
/dev/nvme0n1p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="BD49-965D" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="primary" PARTUUID="13fa6df8-8bdc-4f65-bb54-a59281228cfa"
/dev/nvme0n1p2: LABEL="volumio" UUID="9c8277da-dca0-440f-9fd2-13af79d0ef7c" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="17137f70-81ff-4dac-a4e0-ad0e63ee72fd"
/dev/mmcblk0p3: LABEL="volumio_data" UUID="3bba9da0-7f1b-4d9e-aef5-c0cdf6d74a8c" BLOCK_SIZE="1024" TYPE="ext4" PARTUUID="6606bc33-03"
/dev/mmcblk0p2: LABEL="volumio" UUID="cafa11af-4043-4b82-b2f1-cf9789a0d0ff" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="6606bc33-02"
/dev/loop0: TYPE="squashfs"
When I IP to RPi from Win PC I see…
\\192.168.0.66\
  Internal Storage
    |-lost+found
  nas
  usb
When I Try to copy music from Win PC to RPi 192.168.0.66\Internal Storage\ I get
FAIL - Destination Folder Access Denied
You need permission to perform this action
Which appears to be a File ownership thing which I can’t change within Windows Security permissions
(I can see volumio@volumio:/data/INTERNAL via ssh)
All fixed…
Repartitioned + formatted (Fat32) SSD on WinPC and labelled issd
Copied across music (1.4TB)
Made a new SD card with Volumio 4.069
Installed NVMe SSD on Rpi5 and Volumio saw all music AOK
All shows up in INTERNAL in Volumio browser page - can copy new music straight across to here \192.168.0.66\Internal Storage\Music
Regards
[quot]
[/quote]
thank you
Blockquote yaoiniymalchik
1
nerd
10d
[quot]
[/quote]
thank you
