Today I burnt the Volumio3 into the SD card of raspberry pi. A strange problem is that the raspberry pi can’t access the internet but can access the local network. It mounted the folder that I shared publicly on another PC and I can access the pi with ssh. However, I can’t play the audio stream of webaudio and the command “sudo apt-get update” also failed due to the loss of network connection.
@Tucik_Fadu - Question: which interface are you using for networking (wired, WiFi or HotSpot)? If you have all 3 you might turn off two of them in Settings>Network and then reboot your Pi.
oh, thanks i will have a try
