I.e. I2S was there, the HAT could be selected and it was working after a reboot. BTW: the Volumio documentation still lists compatibility for some HiFiBerry boards.
Hi Steven,
thanks for the quick response. This worked for me - perfect. Actually much more smothly compared to buster. Anyhow, I2A switch did not show up compare to the RPI version.
Cheers,
Christoph
The problem was located and will be fixed soon.
This only happens with specific boards, like the sndrpihifiberry and sndrpirpidac @cgs and @Sgoyvaerts used. This thread will go on the issue list, with a list of supported dacs with Tinkerboard.
Hello. Due to a failure, I had to replace the Asus Tinker Board S computer in my Volumio Primo player. I installed a fresh Volumio Tinker Board system, version 3.779. I was able to play audio on the HDMI output, but there was no option to select either SPDIF or analog RCA outputs. After reading this thread, I added ‘intf:dtoverlay=es9028dac’ to the hw_intf.conf file. Now I can select these outputs in the playback options, but unfortunately the sound does not appear on either the SPDIF or RCA output. Is there anything else I should do to get this to work?
