Thanks!
Hi @mervinio
When it will be fixed the issue with radio stations, press play the radio starts after 3 4 minutes. In this way I can not use volumio⦠It is just to annoyingā¦
This happens on radio stations with variable bitrate. This is an MPD issue, which we will try to fix soon. If it happens to all your stations, do you have a DSP enabled?
We are working on a fix, but it probably wonāt be in time for release.
I can suggest to all having issues with webradios to do this:
- Enable resampling from playback options
- Set it to 44.1 and 16 bit
- Webradio will now play without issues
Let me know if that fixes your issues, this will help us fixing it
Hello
I have the same problem. The radio starts and stops 10 seconds later. There is a blank and the radio starts again.
I did some tests. And I realize that only the RadioFrance radios are impacted.
Christian
Can you guys share the URL of the RadioFrance radios that are impacted?
This will afect qobuz high res? ?
HI?
I have the same problem after modify resampling!
Guys, please provide the webradio URLs
Ok
France culture :
http://direct.franceculture.fr/live/franceculture-hifi.aac
Christian
Here it works just fine.
Are you guys using Volumio2 or Volumio3?
I use volumio3
Another issue I have is that after a while the volumio page from android phone hangs up⦠In order to recover I need to execute volumio vrestart.
We need logsā¦
Hola. Soy Ale y hace aƱos que soy MyVolumio Virtuosso.
Estoy teniendo problemas con la versión 3.159:
-Estoy loggeado y sin embrago para entrar en Plugins Store me dice que debo estar loggeado.
-No funciona la pestaƱa de Radios.
Hello. Iām Ale and Iāve been MyVolumio Virtuosso for years.
Iām having problems with version 3.159:
-Iām logged in and yet to enter the Plugins Store it tells me that I must be logged in.
-The Radios tab does not work.
Thanks.
Raspberry P 4b+
Dacberry RDY+
Volumio 3.159
please check if the previous version is removed from myvolumio, as Virtuosso only allows 1 installation.
Hi again,
Regarding 8080s radio, the songs are not synched with album art on my display.
I listen this radio almost 80% on my time and the manifest ui looks great⦠Thanks
Logs
http://logs.volumio.org/volumiobuster/4I1pZwV.html
Hey is there any way I can help to debug my wifi issue? I can ssh and run commands but Iām unsure of how to fix.
Sometimes I have the same issue but only from HDMI screen. From a web browser it correctly says that Iām logged in. Is it the same for you?
Hola carlito_s. Estoy en un navegador web: Chrome⦠Y en safari me dice exactamente lo mismo. Gracias por tu respuesta.
Hi carlito_s. Iām in a web browser: Chrome ⦠And in safari it tells me exactly the same thing. Thanks for your answer.
