I used my raspberry a long time with Volumio 2 and audio output via HDMI to an external DAC which is connected to the amplifier.
Now I try to setup volumio 3 on a new SD card, but I fail to make the adio output working via HDMI again. Since the setup of the volumio 2 HDMI solution is long time ago I do not remember anymore what I did to make it work.
In the config file the setting seems ok: hdmi_force_hotplug=1
During the wizzard setup the HDMI output was not offered as an option. Only headphones or I have to select a DAC hardware what I do not use.
Does anyone has any idea how to make this run?
Here the system data:
OS info
Version of Volumio: 3.396
Hostname: volumio
Kernel: 5.10.92-v7+
Governor: performance
Uptime: 0 days, 0 Hrs, 15 Minutes, 31 Seconds
Audio info
Hw audio configured: Headphones
Mixer type: Hardware
Number of channels: 8
Board info
Model: Raspberry Pi 3 Model B Rev 1.2
Version: a02082
Firmware Version: Jan 20 2022 13:58:22 - bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
Regards
Jo
