Volumio 3 doesn't see either my USB drive or SD card with Rivo
I have just set up my new Rivo (with Volumio 3). Everything works just fine, but I don’t see my music library either in SD card or in USB drive.
I had been using this very drive with Bluesound Node, Eversolo DMP A6, and Silent Angel Munich M1T without any problem.
Any advice? Thanks.
Hi @csabato,
Have you rebuilt or updated your sources using the Sources / My Music / Update and/or Rescan options? You need to manually instruct Volumio to look for music within connected devices. The re-indexing proces may take a little while depending on your library size and drive speeds.
Yes I have done it, but even after it I had to wait for my library to appear.
But finally it has appeared, so everything is fine :slight_smile:
Thanks!
Great! Glad this helped.
Every time you add a new album, make changes to your library, and/or connect/disconnect a new drive with music, you need to reindex or rescan your library this way so your sources are always up to date.
Also, as a recommendation, unless you’re using a network drive, from my experience it’s best to store your music on a thumb or external drive. This makes it easier to update in the future.
