Hi, I’m on the Virtuoso yearly plan and just updated to Volumio 3.
I can’t acces the plugin store as Volumio keep telling me to login to MyVolumio althoug I’m already logged in to Volumio and can see my plan under my name in the top.
I apologize if this is not the correct place to ask, but where do I find the actual plugin store? Is there somewhere in Volumio that is called ‘Plugin store’ or are you referring to something else? There is no information or manual explaining this (that I could find).
That was the first place I tried to look, but there is nothing called ‘Plugin store’ there. There is only the old ‘Search plugins’ and ‘Installed plugins’ that was there in Volumio 2. I got the impression that there would be something new called ‘Plugin store’ in Volumio 3.
I will try to create a free myVolumio account in addition to my virtuoso account and see if that makes a difference.
I am experiencing the same issue: I am logged in to MyVolumio, but I get an message box on the plugins menu saying “Please login. To access the plugins store you need to login to MyVolumio”.
