Cyclone Windows Mini PC 2 by SUMVISION
Volumiobuster-3.080 installed to eMMC. Couple of issues to report.
Wireless is not working , just driver do not pick up WiFi part of rtl8723bs
Kiosk mode not started after boot. I had to add 15 second delay in service start.
Rather than that , just brilliant software for outdated multimedia PC with SMSL M400 USB DAC
======Here is Dmesg=========
bash-5.0# dmesg | grep bt
[ 28.289815] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723bs_fw.bin
[ 28.295689] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723bs_config-OBDA8723.bin
bash-5.0# lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 22)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers (rev 22)
00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit (rev 22)
00:0b.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller (rev 22)
00:11.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SDIO Controller (rev 22)
00:12.0 SD Host controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SD Controller (rev 22)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 22)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 22)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 22)
bash-5.0# inxi -Fxxxz
System: Host: volumioattic Kernel: 5.10.35 x86_64 bits: 64 compiler: N/A Console: tty 0 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop System: Mini PC product: Mini PC v: 2.93 serial: N/A
Mobo: Mini PC model: Cherry Trail CR serial: N/A UEFI: American Megatrends v: 5.11 date: 05/09/2016
CPU: Topology: Single Core model: Intel Atom x5-Z8300 bits: 64 type: MCP arch: Airmont rev: 3 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 2880
Speed: 1600 MHz min/max: 480/1840 MHz Core speed (MHz): 1: 1600
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:22b0
Display: server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 256x96
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit driver: intel_atomisp2_pm
v: kernel bus ID: 00:03.0 chip ID: 8086:22b8
Device-2: Thesycon System & Consulting type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:2
chip ID: 152a:85dd
Sound Server: ALSA v: k5.10.35
Network: Message: No Device data found.
Device-1: ASIX AX88772B type: USB driver: asix bus ID: 1-3:3 chip ID: 0b95:772b serial:
IF: eth0 state: up speed: 100 Mbps duplex: full mac:
Drives: Local Storage: total: 262.00 GiB used: 166.29 GiB (63.5%)
ID-1: /dev/mmcblk2 model: 032G72 size: 29.12 GiB serial: rev: 0x7 scheme: GPT
ID-2: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1 size: 232.88 GiB serial: rev: 1.00 scheme: MBR
Partition: ID-1: / size: 25.05 GiB used: 475.5 MiB (1.9%) fs: overlay source: ERR-102
ID-2: /boot size: 168.4 MiB used: 57.7 MiB (34.3%) fs: vfat dev: /dev/mmcblk2p1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 140 Uptime: 3h 31m Memory: 1.86 GiB used: 539.0 MiB (28.3%) Init: systemd v: 241 runlevel: 5 default: 2
Compilers: gcc: 8.3.0 alt: 8 Shell: bash (sudo) v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
