Please it is clear beta version comes with no plugin and no support for it. You can test what you want but do not ask here. Thanks.
sorry , I have asked only about the /var/log folder size ,I want to use plugins for listening music âŠ
thanks
Please refer to the announcement where we specifically asked testers NOT to install additional software like plugins until we release them for testing.
By joining the testprogram you have accepted to abide by the rules!
Allo Piano 2.1 can be set to âDual Monoâ - but still doesnât work (3.051 and 3.054)
Interesting: If i switch I2S DAC off, then click on save i get the Piano 2.1 shown in the dropdown with HDMI and headphones.
Then i choose the Piano 2.1 there - then there is sound
and it is dual mono.
Only volume control is not workingâŠ
Would it be possible to include the new Allo BOSS2 HD DAC.
That would be very nice.
Many Thanks
rost21A
v3.051 on RPi4 everything seems good. Just out of curiosity enabled âtest modeâ and checked for updates, and got:
(1) I didnât think updates were running;
(2) this appears to be (from âFIXESâ) to be x86 specific.
Update apparently works ok, with system reported as 3.054 but exactly what have I updated?
Yes, these were more x86-specific this time, you canât always say.
Beta affects both platform ways.
3.054 correct a alsa problem with float format with some files such as wma, and probably other things
Hello ,
I have an an issue with DSD files on v 3.054
If I play DSD files in Volumio the files is shown as 5.6 MHZ DSD as seen below
Blockquote
volumio@volumio:~$ volumio status
âstatusâ: âplayâ,
âpositionâ: 0,
âtitleâ: âHelloâ,
âartistâ: âAdeleâ,
âalbumâ: â25â,
âalbumartâ: â/albumart?cacheid=53&web=Adele/25/mega&path=%2FNAS%2FSynology%2FDSD%2FAdele%20-%2025%20(2015)%20%5BDSD128%5D&metadata=falseâ,
âuriâ: âmnt/NAS/Synology/DSD/Adele - 25 (2015) [DSD128]/01. Hello.dsfâ,
âtrackTypeâ: âdsfâ,
âseekâ: 12200,
âdurationâ: 296,
âsamplerateâ: â5.64 MHzâ,
âbitdepthâ: â1 bitâ,
âchannelsâ: 2,
ârandomâ: null,
ârepeatâ: null,
ârepeatSingleâ: false,
âconsumeâ: false,
âvolumeâ: 74,
âdisableVolumeControlâ: false,
âmuteâ: false,
âstreamâ: âdsfâ,
âupdatedbâ: false,
âvolatileâ: false,
âserviceâ: âmpdâ
On DAC topping display I see 705.6 PCM .
DSD direct mode is set . HW mixer is set .
Thanks for your support
I have found the issue . it was stated in an anotehr thread :
:Volumio version 2.779 (Released: Jun 8 18:35:15 CEST 2020) has reversed functions names for âDSD playback modeâ: âDSD directâ and âDSD over PCM (DoP)â. Personally, I donât mind, but it can be confusing for other Volumio users.â
I have boot up with DOP enabled and now on DAC I see 5.64 DSD .
Could you please fix this in beta version .
thanks
Hi
Hope i am in the right section of the forum.
Usual system is Raspberry Pi 3 in with add-on systems Suptronics X5000k http://www.suptronics.com/miniPCkits/x5000k.html
DAC ES9023
Harddrive standard SATA
Addon USB Wifi Dongle TP-LINK WN823N (RTL8192 EU)
= Wifi USB dongle recognized and working with Volumio 2 (lastest version)
= Wifi USB dongle not working with Volumiobuster-3.051-2021-03-06-pi
Log http://logs.volumio.org/volumiobuster/OLGZYvH.html
Thanks in advance
What exactly doesnât work?
Mar 14 14:08:40 blackbox wireless.js[1265]: Connected to: ----Freebox-34267B-Stable
Mar 14 14:08:40 blackbox wireless.js[1265]: ----
Mar 14 14:08:40 blackbox sudo[1394]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 14 14:08:40 blackbox sudo[1394]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 14 14:08:40 blackbox sudo[1394]: pam_unix(sudo:session): session closed for user root
Mar 14 14:08:40 blackbox dnsmasq[737]: reading /etc/resolv.conf
Mar 14 14:08:40 blackbox dnsmasq[737]: using nameserver 192.168.1.254#53
Mar 14 14:08:40 blackbox dnsmasq[737]: using nameserver 208.67.222.222#53
Mar 14 14:08:40 blackbox dnsmasq[737]: using nameserver 208.67.220.220#53
Mar 14 14:08:40 blackbox wireless.js[1265]: ... joined AP, wlan0 IPv4 is 192.168.1.49, ipV6 is undefined
Mar 14 14:08:40 blackbox wireless.js[1265]: It's done! AP
Mar 14 14:08:40 blackbox systemd[1]: Started Wireless Services.
It took a couple of tries, but it seems to have connected?
But this one
Hi
Thanks for the quick check.
It did connect, but, i think given the strength of the signal and proximity to my router (less than 1meter), it was only using the Raspberry Pi 3 board Wifi, not the TP-LINK USB dongle.
This was for troubleshooting that i put the Raspberry so close (and with ethernet cable), but i am usually using the Raspberry much farther away and need the longer range of the wifi dongle. With Raspberry wifi alone, i usually canât connect.
You can suggest commands for me to try to troubleshoot a bit, maybe i am wrong with my assessment, but the led of the Wifi dongle doesnât blink with Volumio 3, yet blinks with Volumio 2.
Regards
Is the RTL8192 EU supported in vanilla Raspbian image? If I recall correctly, it required special drivers that that werenât included by default with Jessi. I wonder if that is still the case with Buster?
Hi
I donât know how to check properly, but doing a search and checking various websites, it seems many are providing specific methods to install that specific driver by download & compile or some just suggest apt-get install firmware-realtek, but it is is a non-free driver.
Big question for me: is it like this now just because Volumio 3 is in Beta and would be fixed when dubbed Stable, or would it stay like this because Volumio 3 would focus on Raspbian vanilla image ?
rtl8192eu was part of the set of custom wifi packages which were taken from the MrEngmanâs repo, see https://github.com/volumio/Build/blob/a3ed097bbb47a473798ffcf099aed5e16d642bbf/scripts/raspberryconfig.sh#L275
As @GĂ© said, previously we were pulling in a bunch of custom WiFi drivers from MrEngmanâs collection. A lot of them are now in the tree for newer kernels. But the RTL8192EU doesnât seem to be.
firmware-realtek should already be included, so unsure why itâs not picking up this chipset?
Can you check if itâs installed?
dpkg -l firmware-realtek
We should do an evaluation of what is still required from MrEngmanâs collection and fetch them. Ofc, this would be Pi specific, and wonât help other arm boardsâŠ
Could you confirm if the drivers compiled by MrEngman work for you?
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi
I installed version 3.051 and I still have the same problem with the wireless network: I have to reconfigure it every time the system reboots, which is in Off mode. I use Static IP.
Rasp 3 + Allo Boss
When I installed the latest version of Buster, 3.051, in System Settings, I changed the name of it to âVolumio_3â.
I use Putty and see
volumio @ volumio3: ~ $
And when doing Sudo nano ⊠I continually get
sudo: unable to resolve host volumio3: System error
I fixed it by renaming it to Volumio3 in
sudo nano / etc / hostname
and in
sudo nano / etc / hosts
I use Rasp 3 + Allo Boss + V 3.051
