Volumio 3 Beta test: Raspberry Pi with kernel 6.6
Hey @11128,
Please monitor to top page of this thread listing plugins and core functions. Once all are confirmed working across entire Pi family, only then the stable release will follow.
updated to system v3.772 everything okay. Immediately updated the rotary encoder ll to v1.1.23 beta, the Push button now works again.
Raspberry Pi 5, 4 gb.
Edit:
Only when I disable and enable the rotary encoder plugin II and then disable the infrared plugin do I see an error.
also afterwards an error when switching on the rotary encoder, unfortunately I can’t take a screenshot… the error disappears too quickly.
log error should be there.
http://logs.volumio.org/volumio/LPvXe2u.html
both the infrared plugin and rotary encoder work okay.
Update to v3.772, Raspberry Pi 3.
Update plugin rotary encoder ll to 1.1.23 bèta, pushbutton now okay.
Same problem as above.
Turn of/on rotary encoder ll fault by turn off infrared plugin.
log
http://logs.volumio.org/volumio/xHtk8l5.html
Both rotary encoder ll and infrared working okay.
Fault turn off infrared
Fault turn off rotary encoder ll
did some more testing.
When turning the rotary plugin off and on, the infrared stops working (it is switched on and green) and vice versa when the infrared plugin is turned off and on, the rotary encoder stops working.
To get this right again, a reboot is the only solution.
on a raspberry pi3.
edit: same problem on a raspberry pi 5, 4gb model.
3.779 available
As you could all noticed, we are moving from Beta to Release Candidate phase already.
v3.779
QA internal testing.
Version alignment across Volumio OS.
I’m glad to announce that the version 3.779 has been promoted to stable, after extensive QA testing.
This thread can be closed now, thanks everyone that made this possible!
A post was merged into an existing topic: Hifiberry Digi2 Pro is not recognized by Volumio
