Ich want to create a Inetradio with a Rasp 3b+ with a touch Display and Volumio.
The Rasp with Volumio works fine over a browser session with an other device, I can change the webradio stations or play Music from my NAS.
But the Touchscreen show only the DOS Session with promt etc… I can not start the Gui. And I can not download a GUI Plugin :-(.
Can I use the Gui only when I a payed member are? I don’t wont to have all the other features from Volumio, only I wont is hear webradio and control it over the GUI.
first you can try a reboot and try enable it and after that
you can uninstall this version and in details you can find other versions try the 3.3.1 version.
