Issue that I’m going to mention is already reported(I also reported and provided necessary information) and known to Volumio team, but it is not yet mentioned in known issues list. This issue is tested on ASUS Tinkerboard 1 (without S) and still exist in V 3.179.
After Volumio 3 came out, I updated my system. Updating itself went without any problem. However Volumio 3 is unable to automatically recognize and mount external USB drive if it is formatted into ext4(Linux). I tested drive with exFAT file system and it worked fine.
There are two solutions at the moment:
SOLUTION 1 - If version 2 is working and version 3 doesn’t offer nothing new and necessary, it is good idea to stay with it at the moment.
SOLUTION 2 - Volumio 3 base system itself supports ext4 and drivers are working correctly, problem is somewhere in UI component. To use drive that is formatted into ext4, it is necessary to SSH into Volumio box and manually mount it into “/mnt/USB” After mounting it is also necessary to manually rescan music collection “Settings->Sources->Rescan”. Manually mounted drive is visible until restart, then steps above must be executed again.
You probably sent a log before, but it would be really good to do one again with Volumio 3.
I know we have had problems automounting usb drives, but I can’t remember we had a report with ext4 being the issue. Howto: Send a log
I’ll have a look as soon as you post a link to the log.
There is something odd about this, there is no udev partition mount request, though the M3 Portable is “registered” as device /dev/sda. It is not a UAS type of drive, so I would expect it to be treated as a normal usb disk.
Did you label the disk?
When you have time, could you do the same, but start without the device connected, wait till you hear the startup sound, plug in the drive and then create the log after a few seconds?
Yes I formatted it into ext4 and labeled it as “Muusika”. It was in exFAT or NTFS when I bought it couple years ago. I post log later, I sent it, but it log address gave 404 error.
No device action visible, it is recognized by the kernel but nothing else happens.
It should have triggered the networkfs plugin, which executes the partition mount request.
But it never gets there.
Could you this for me:
lsblk -l --output-all /dev/sda
Please copy it here, but put a “```” (without the quotes) as a first line and finishing line
That should give you something like this
NAME KNAME PATH MAJ:MIN FSAVAIL FSSIZE FSTYPE FSUSED FSUSE% MOUNTPOINT LABEL UUID PTUUID PTTYPE PARTTYPE PARTLABEL PARTUUID PARTFLAGS RA RO RM HOTPLUG MODEL SERIAL SIZE STATE OWNER GROUP MODE ALIGNMENT MIN-IO OPT-IO PHY-SEC LOG-SEC ROTA SCHED RQ-SIZE TYPE DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO WSAME WWN RAND PKNAME HCTL TRAN SUBSYSTEMS REV VENDOR ZONED
sda sda /dev/sda 8:0 a230ec04 dos 128 0 0 0 Samsung_SSD_870_QVO_1TB S5SVNG0N826664A 931.5G running brw-rw---- 0 512 0 512 512 0 mq-deadline 64 disk 0 512B 2G 0 0B 0x5002538f7080d5c8 0 0:0:0:0 sata block:scsi:pci 1B6Q ATA none
sda1 sda1 /dev/sda1 8:1 vfat C965-4E94 a230ec04 dos 0xef a230ec04-01 0x80 128 0 0 0 512M brw-rw---- 0 512 0 512 512 0 mq-deadline 64 part 0 512B 2G 0 0B 0x5002538f7080d5c8 0 sda block:scsi:pci none
“Loop” means parted reports a missing partition table.
You have an incorrectly formatted disk, this will not work.
Always creating a partition table, especially if formatted on Windows before.
Only then create a new file system.
I haven’t used this disc on windows machine, I don’t have any I bought it and first just reformatted it. I can reformat disc after back-up and then try again.
It is interesting that my ArchLinux machine don’t have no problems with it. Volumio 2 also worked just fine with this disc. Mounting it manually works also in Volumio 3.
Then it is probably something to do with new Debian base system.
Volumio 2 probably worked because it could use a specific debian package for automounting, but that was with Debian jessie, the package does not exist anymore with buster, so we need to rely on udev device actions, which are reported by the kernel.
The issue with a missing partition table is that udev never generates a device action to add a partition, because there is no partition table.
I confirm that I got my disk problem solved. Now my disk is automatically detected and music is accessible.
I created partition table and then created partition. And only then formatted created partition into ext4. I don’t remember how I got such kind of bad habit of not creating partition tables Maybe just thought that it is not necessary for non-system disks.
Good thing is that, now I can introduce Volumio 3 in estonian Hi-Fi enthusiasts FB group!
Glad I could help. I think this can be added to the issues list for others to profit from.
It is actually the first time that I have been able to go to the bottom of this with your help.
I did a bit of research about formatting disk as I did VS using partition table. Turns out that not having partition table is considered somewhat unusual, but not incorrect or wrong. If partition occupies whole disk, then partition table is not needed unless it is system disc with bootable OS. Partition table serves as index for disk when multiple partitions are used.
