Volumio 3.799 does not upload new albumart
I have problem that from my latest local library album the album art is not be updated. So there is no album art on that album.
Did you reset the album art cache?
yes I did. and a new scan. The album is flac and has all metadata in it.
http://logs.volumio.org/volumio/pyItuL9.html
If Volumio can’t find a good match on musicbrainz, it will return empty.
For those you can add a Artists.jpg and Cover.jpg to the correspondig folders and clear the cache again.
aha oke thx I will try it. It is a new release that is then the reason for no cover. Can confirm , it works…thx!
No I expect that Musicbrainz for example added a new entry for the release in question or made updates to existing ones. If Volumio can’t get a good hit, or get 40 results, Volumio will skip it. Better skip it, then displaying completely wrong info.
Above is not exact science, as I also experience the same even with pretty common albums. Even with mulitple runs within a few hours. One run gets the correct info, the next the same fails.
