Good morning everyone, I’m Roberto and it’s the first time I’ve written on the forum.
Yesterday I updated to the new version of Volumio (see it in the title).
The system is a RaspBerry Pi 2B with a 16GB Sandisk microSD.
After the update, WIFI stopped working. With the LAN cable everything works fine.
I tried using three different dongles but nothing.
They stay off, and if I try to turn them on; Volumio saves settings but WIFI remains off.
Any advice?
22/12/2024 with version 3.569-2023-10-20 the wifi started working correctly again but not with all dongles, only with the Tp-Link wn725n - Realtek RTL8188EUS chipset
with the two Gembird WNP-UA-005 cards - Chipset: RTL8192EU does not work
greetings to everyone
P.S.: I advise anyone in the same situation as me to disable automatic updates.
`# lsusb ---------------
Bus 001 Device 004: ID 0781:5567 SanDisk Corp. Cruzer Blade
Bus 001 Device 005: ID 0bda:818b Realtek Semiconductor Corp. RTL8192EU 802.11b/g/n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
lsusb -t ---------------
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 480M
lsusb -v ---------------
Couldn’t open device, some information will be missing
Couldn’t open device, some information will be missing`
