Volumio 3.5 Supersearch and Infinity Playback Public Beta Testing
Und wenn es mit dem Router zusammenhängt, frage ich mich, ob der Router wirklich der Übeltäter ist, oder ob es ein Problem der Implementierung ist, die mit bestimmten Verhaltensweisen von Routern nicht umgehen kann (?)
[Google translate] as not all people speak German;
And if it’s router related, I’m wondering if the router really is the culprit, or if it’s an implementation issue that can’t handle certain behaviors of routers (?)
His answer was to another user above.
I know, still we use English on this forum.
My answer was to Axel (at least on mobile it even indicates that)
sorry for the German, it was in the clipboard and when I pasted it I thought it’s the text in English :-/
Thx, got it
no problem :grinning:
I translated it, as routers can be very annoying. linksys as an option for caching streaming things, which actually breaks streaming, when turned on. So as it might be interested to more people I translated it.
@volumio,
Hi Mi,
What logic is being used with infinity playback.
I started with a list of pop and rock music. On the first retrieval it included a Dutch artist in local language. Now on every new refresh it only get’s Dutch tracks.
Does infinity consider the starting track on refilling the queue, or the current played track when a new call for tracks comes?
Hey guys just signed up with a trial to test the premium features before deciding about the lifetime sub.
The Supersearch isn’t working, not sure if i’m missing anything? The thing just spins out.
Does the player have to be in test mode or require a plugin? I’ve clear site data for volumio. Keen to test this and the ‘playing away from home’ today.
Thanks!
No, doesn’t require test mode or a plugin. Maybe your account is not fully processed in the system, so it may just start working in a few hours.
no, just a full or trail version.
Hit the switch, enter your search and hit the green arrow.
Please make sure you run the latest stable release V3.512 and not a test version.
And have a library loaded.
Hi G-rig,
we noticed that some plugins (like youtube, soundcloud and others) seem to break Supersearch and infinity playback.
I recommend to disable them and retry.
PS: We are about to release a new release in about 10 days which fixes that, disabling supersearch on non-compliant plugins and allowing you to select which plugins are included in supersearch and infinity.
Infinity matches the last track on the queue, so if your last track is a dutch artist, it gets similar tracks to it.
Thanks for the conformation,
ok no worries, thanks!
Hi guys, I got version 3.545.
I don’t currently have Tidal so just testing with my own library (have plenty of tracks 18,000 or something).
The only plugin besides touch and now playing i have loaded is YouTube Cast Reciever. I’ve just disabled so will reboot and test (Edit no difference).
Ta
Also downgrade to V3.512, you’re running a test version.
Ok, I only using beta because that YouTube cast receiver doesn’t work otherwise.
A system reset maintained the same version. Just doing a brand new flash of the SD. PITA taking the back off the official touchscreen.
Edit: working now ;). Supersearch isn’t showing as many results as the normal search, bit odd.
Will give it a bit longer - library appears to all be there but in reality may still be syncing(?)
‘Play here’ seems to work with phone on 4g so will listen at work and test it out :P.
Thanks,
Any kind of network or router tricks for the supersearch and listening away from home to work better? Not sure if my router level ad blocker or Skynet (firewall) affects it but very slow to respond and doesn’t show the results you’d expect or none.
Massive delay when using with myvolumio.org but guess it’s to be expected. It’s still great you can access play albums as long as you just leave an album on and do t touch it. A temporary download to play offline probably be better before leaving the house. I think I’m doing it right hitting ‘play here’, and changed the device to headphones not the DAC before that.
I don’t currently have streaming, but can the Ai stuff mix your own collection and tidal etc?
Thanks :+1:
This mainly depends on your connection speed (specifically upload speed) and your location.
Yes, the AI DJ and Supersearch mix your content of files and streaming. And actually, at least one streaming service is recommended for optimal results (they have millions of songs to pick from, compared to some thousands in your library).
