Hello dear community,
I’m new to the forum and have a problem with Volumio. I got it to work on my Rpi3b + and tried to install the drivers for my 3.5 inch display using SSH.
According to the manufacturer’s instructions, I should do the following:
sudo rm -rf LCD-show
git clone https://github.com/goodtft/LCD-show.git
chmod -R 755 LCD-show
cd LCD-show
sudo ./LCD35-show
But when I try to do this, the following errors appear:
volumio@netzwerkplayer:~$ sudo rm -rf LCD-show
volumio@netzwerkplayer:~$ git clone https://github.com/goodtft/LCD-show.git
Cloning into 'LCD-show'...
remote: Enumerating objects: 71, done.
remote: Counting objects: 100% (71/71), done.
remote: Compressing objects: 100% (53/53), done.
remote: Total 1257 (delta 45), reused 39 (delta 17), pack-reused 1186
Receiving objects: 100% (1257/1257), 773.71 KiB | 592.00 KiB/s, done.
Resolving deltas: 100% (826/826), done.
Checking connectivity... done.
volumio@netzwerkplayer:~$ chmod -R 755 LCD-show
volumio@netzwerkplayer:~$ cd LCD-show/
volumio@netzwerkplayer:~/LCD-show$ sudo ./LCD35-show
[sudo] password for volumio:
2020
need to update touch configuration
Selecting previously unselected package xserver-xorg-input-evdev.
(Reading database ... 29802 files and directories currently installed.)
Preparing to unpack .../xserver-xorg-input-evdev_1%3a2.10.6-1+b1_armhf.deb ...
Unpacking xserver-xorg-input-evdev (1:2.10.6-1+b1) ...
Processing triggers for man-db (2.7.5-1~bpo8+1) ...
dpkg: dependency problems prevent configuration of xserver-xorg-input-evdev:
xserver-xorg-input-evdev depends on xorg-input-abi-24; however:
Package xorg-input-abi-24 is not installed.
xserver-xorg-input-evdev depends on xserver-xorg-core (>= 2:1.18.99.901); however:
Version of xserver-xorg-core on system is 2:1.18.4-2+rpi1.
dpkg: error processing package xserver-xorg-input-evdev (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
reboot now
Connection to 192.168.178.63 closed by remote host.
Connection to 192.168.178.63 closed.
Since the reboot, my Volumio image doesn’t want to boot either. I tried several options, websites and Google, but got no further. I am really desperate.
One more note: I downloaded and activated the plug-in for the Volumio touch display first!
It would be extremely nice if someone could help me.
Greetings Leon
Volumio Information
Volumio Version: 2.0
Hardware: RaspberryPi 3b+
DAC: -
gvolt
November 16, 2020, 2:21pm
2
Hi @S-Informatik ,
what is the brand and exact model name of the display?
Flash the Volumio image again. Then don’t run the LCD-show script. We can do the necessary steps one by one.
Thank you @gvolt ,
Quimat 3,5’’ Zoll
I uploaded a picture, maybe that will help too.
love greetings leon
gvolt
November 16, 2020, 8:39pm
4
Thanks for the info
Please flash a fresh Volumio image if not already done.
After Volumio has started and settled down open /boot/userconfig.txt, add
dtparam=spi=on
dtoverlay=tft35a:rotate=90
and save the file.
Reboot.
Then install the Touch Display plugin and enable it. Report back if the display and possibly touch already work.
I did it exactly according to your instructions but unfortunately no success. The display shines black with background lighting. I restarted it after activating the plugin, but now it stays white. However, Volumio continues to boot.
LG Leon🙂
thank you for your help
gvolt
November 16, 2020, 9:24pm
6
What Volumio version did you flash?
Did you see any error messages after enabling the plugin?
Please post the results of
cat /boot/config.txt
cat /boot/userconfig.txt
cat /usr/share/X11/xorg.conf.d/99-fbturbo.conf
ls -al /dev/fb*
and
systemctl status -l volumio-kiosk.service
The version is the volumio-2.834-2020-09-24-pi.
As far as I could see, there were no errors installing the plugin.
volumio@volumio:~$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
volumio@volumio:~$ cat /boot/userconfig.txt
dtparam=spi=on
dtparam=spi=on
volumio@volumio:~$ cat /usr/share/X11/xorg.conf.d/99-fbturbo.conf
# This is a minimal sample config file, which can be copied to
# /etc/X11/xorg.conf in order to make the Xorg server pick up
# and load xf86-video-fbturbo driver installed in the system.
# When troubleshooting, check /var/log/Xorg.0.log for the debugging
# output and error messages.
# Run "man fbturbo" to get additional information about the extra
# configuration options for tuning the driver.
Section "Device"
Identifier "Allwinner A10/A13 FBDEV"
Driver "fbturbo"
Option "fbdev" "/dev/fb0"
Option "SwapbuffersWait" "true"
EndSection
volumio@volumio:~$ ls -al /dev/fb*
crw-rw---- 1 root video 29, 0 Nov 16 21:06
volumio@volumio:~$ systemctl status -l volumio-kiosk.service
● volumio-kiosk.service - Volumio Kiosk
Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; disabled)
Active: active (running) since Mon 2020-11-16 21:09:34 UTC; 40min ago
Main PID: 1197 (startx)
CGroup: /system.slice/volumio-kiosk.service
├─1197 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh -- -nocursor
├─1221 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0 -nocursor -auth /tmp/serverauth.qwgJrZRHvf
├─1222 /usr/lib/xorg/Xorg :0 -nocursor -auth /tmp/serverauth.qwgJrZRHvf
├─1330 /bin/bash /opt/volumiokiosk.sh
├─1347 /usr/bin/ssh-agent /opt/volumiokiosk.sh
├─1352 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbox-autostart OPENBOX
├─1353 /usr/lib/chromium-browser/chromium-browser --enable-pinch --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --simulate-outdated-no-au=Tue, 31 Dec 2099 23:59:59 GMT --disable-pinch --kiosk --no-first-run --noerrdialogs --disable-3d-apis --disable-breakpad --disable-crash-reporter --disable-infobars --disable-session-crashed-bubble --disable-translate --user-data-dir=/data/volumiokiosk http://localhost:3000
├─1379 /usr/bin/pulseaudio --start
├─1388 /bin/sh /usr/bin/start-pulseaudio-x11
├─1389 /usr/bin/xprop -root -spy
├─1392 /usr/lib/chromium-browser/chromium-browser --type=zygote --noerrdialogs --user-data-dir=/data/volumiokiosk --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so
├─1395 /usr/lib/chromium-browser/chromium-browser --type=zygote --noerrdialogs --user-data-dir=/data/volumiokiosk --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so
└─1446 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-3d-apis --disable-breakpad --disable-pinch --enable-pinch --enable-features=AutofillCreditCardSigninPromo<AutofillCreditCardSigninPromo,AutofillProfileCleanup<AutofillProfileCleanup,DocumentWriteEvaluator<DisallowFetchForDocWrittenScriptsInMainFrame,ExpectCTReporting<ExpectCTReporting,IncidentReportingDisableUpload<SafeBrowsingIncidentReportingService,IncidentReportingModuleLoadAnalysis<SafeBrowsingIncidentReportingServiceFeatures,IncidentReportingSuspiciousModuleReporting<SafeBrowsingIncidentReportingServiceFeatures,MaterialDesignUserManager<MaterialDesignUserManager,NegotiateTLS13<TLS13Negotiation,NetworkTimeServiceQuerying<NetworkTimeQueries,NewAudioRenderingMixingStrategy<NewAudioRenderingMixingStrategy
Nov 16 21:09:34 volumio startx[1197]: Markers: (--) probed, (**) from config file, (==) default setting,
Nov 16 21:09:34 volumio startx[1197]: (++) from command line, (!!) notice, (II) informational,
Nov 16 21:09:34 volumio startx[1197]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 16 21:09:34 volumio startx[1197]: (==) Log file: "/var/log/Xorg.0.log", Time: Mon Nov 16 21:09:34 2020
Nov 16 21:09:34 volumio startx[1197]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Nov 16 21:09:34 volumio startx[1197]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Nov 16 21:09:35 volumio startx[1197]: modprobe: FATAL: Module g2d_23 not found.
Nov 16 21:09:39 volumio pulseaudio[1379]: Unable to contact D-Bus: org.freedesktop.DBus.Error.Spawn.ExecFailed: /usr/bin/dbus-launch terminated abnormally without any error message
Nov 16 21:09:39 volumio pulseaudio[1379]: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method "GetProperties" with signature "" on interface "org.bluez.Manager" doesn't exist
Thanks for your Help @gvolt
gvolt
November 16, 2020, 10:08pm
8
I forgot to mention it in post #3: You need to download “tft35a-overlay.dtb ” and copy it to “/boot/overlays/tft35a.dtbo”, e.g. (if you downloaded to Volumio’s home directory) with
sudo cp ~/tft35a-overlay.dtb /boot/overlays/tft35a.dtbo
Did you do that or is “tft35a.dtbo” possibly missing?
In fact, I was missing the file. After all, the display is black and glowing within a few seconds after starting the Pi. But there is still no logo or font displayed.
Thanks for your many tips
gvolt:
ls -al /dev/fb*
crw-rw---- 1 root video 29, 0 Nov 16 21:06 /dev/fb0
crw-rw---- 1 root video 29, 1 Nov 16 21:06 /dev/fb1
gvolt
November 16, 2020, 10:37pm
12
Open “/usr/share/X11/xorg.conf.d/99-fbturbo.conf” and try changing the line
to
Option "fbdev" "/dev/fb1"
Then reboot.
Thank you very much, it is actually working now.
Only the touchscreen is not properly calibrated, are there any possibilities?
LG Leon
gvolt
November 16, 2020, 10:55pm
14
Create (or edit) “99-calibration.conf” in “/etc/X11/xorg.conf.d/” so it has the following content:
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "268 3880 227 3936"
Option "SwapAxes" "0"
EndSection
Reboot.
I think the top and bottom are swapped with left and right.
Thanks for all of your help, you know that really well.
gvolt
November 16, 2020, 11:07pm
16
I hope I got it right what is swapped
Try changing “99-calibration.conf” to
Option "Calibration" "3700 115 155 3865"
Option "SwapAxes" "1"
EndSection
gvolt:
3700 115 155 3865
Somehow the values are still wrong.
When I press top left, the pointer is bottom left.
If I press the top right, the pointer is at the top left.
If I press the bottom right, the pointer is at the top right.
If I press lower left, the pointer is lower right.
gvolt
November 16, 2020, 11:32pm
18
I am little tired, so I may be wrong, but I think you need to revert to the values from post #13 except for “SwapAxes” which would remain “1”.
Hey @gvolt ,
I tried different values myself, but without real success. It seems like the X and Y axes of the touchscreen are reversed.
LG Leon
gvolt
November 17, 2020, 11:19pm
20
Could you describe how the touch screen reacts (like in post #16 ) when you use the values from post #13 and set “SwapAxes” to “1”?
You may try adding
Option "InvertY" "true"
Option "InvertX" "true"
to “99-calibration.conf”.
