the 7.9 display looks similar. I wish I could shift it over or get rid of the dead space.
I Have one device now that has started the “Configuration Update Player Successfully Updated” loop again. I updated that device to 3.398, turned off testing mode. Then I did a reboot of the device. After the reboot it was still in the loop so I proceeded with a factory reset and the configuration updated loop continued.
It was stable for a few hours yesterday on 3.396 and I was able to listen to a few podcasts on spotify and my sleep sounds playlist but sometime in the night it started into the loop.
I am still unable to sync multi-room playback when the devices are stable and signed into my volumio premium account.
here are the logs:
http://logs.volumio.org/volumio/NTP88yT.html
seems to be stable now, so I grabbed the logs again to see if it helps in figuring out what is happening.
http://logs.volumio.org/volumio/ofhTV3J.html
Then after a reboot from the GUI power button the loop begins again:
http://logs.volumio.org/volumio/xXCsLDi.html
A reboot also kicked off the configuration update loop on the device that had been stable on 3.396 since Friday:
Please check you DNS settings in your router.
I see a bunch of network errors in your logs.
Please update the DNS in your router to those from Google.
Primary: 8.8.8.8
Secondary: 8.8.4.4
And test again.
It’s always DNS…
Unfortunately my provider has DNS locked on my router and I haven’t had a chance to set up my pfsense in the new place yet. However turning on DNS settings in the networking panel on the devices seems to have worked perfect.
Also seems to have fixed the multiroom playback as well.
Thanks!
Good to hear you’re up and running again.
We have seen multiple occasions, when some connections are being blocked Volumio get into this loop. However this should have been solved with V3.396 @volumio .
The Volumio team is working to get a solution on the -3007 error.
Browse raised the following error Error: getaddrinfo -3007
after a while I have problem with playing. This time a have issue while playing Spotify, but sometimes it happens with Tidal or YouTube cast. Logs attached:
http://logs.volumio.org/volumio/ycQejSj.html
Not occurred before update. To reproduce this error you can switch between sources: playing locally(NAS), Tidal, Youtube Cast, Spotify.
I think something went wrong with flashing your ID.
There are to many errors (138). mainly on audio, kernel panics etc.
Please reflash your SD with Raspberry pi imager.
Don’t install plugins like LMS, YouTube Cast Receiver, YouTube Music, Music Services Shield.
First you need a clean stable install, then move forward.
Link to latest release please!
Within the Volumio menus go to System and click Check Updates.
Sorry - Newbie on this forum - as I posted from the Fast Beta-Test topic I meant a link to the latest beta of Volumio 3. Already a happy Premium user of Volumio 2. Would like to set up a separate CM4 test bench for Volumio 3.
As newby take the final release version, not a beta release.
The “zeroconf: No global port, disabling zeroconf” is not fixed in the latest release. How many people on this thread experiencing this problem did headless/network installs?
