To being with, here’s a description of my setup.
Volumio 3.378 with Volumio Virtuoso (haven’t upgraded to Premium yet)
Allo USBridge Signature (Rpi compute module based) connected via USB to Job Integrated 225 amplifier with built-in DAC. Note that HW vol control is available on the AMP+DAC combo for USB source and this cannot be disabled. Allo USBridge is powered by Allo Shanti LPS.
After first powering on Allo USBridge Signature streamer and Job Amp+DAC and when I try to play any source file (Tidal, Radio Paradise, music off a USB drive), I get a message saying “Failed to open. Error opening ALSA device “hw:5,0”; snd_pcm_hw_params() failed: Input/output error”. Playback session starts but there is no audio. When this error pops up, Mixer Setting in Playback Options screen usually says ‘undefined’ instead of Hardware or Software or None. If I turn off USB and turn on I2S DAC in Volumio Playback Options screen and reboot the streamer and turn USB dac back in, it usually starts playing ok. Sometimes i need to reboot multiple times to get it working ok.
Link for error log file at http://logs.volumio.org/volumio/fiIEbGa.html.
I know this has something to do with Mixer setting as the error does not popup whenever mixer settings are correctly initialized on startup. What could be the reason for this error? Is it because my USB DAC has HW volume control and this setting is not always being detected by Volumio correctly? Is there a ALSA or USB DAC setting that I need to enter manually in the config file so that this works ok all times?
Please help. This is quite frustrating and I don’t want to give up on Volumio.
Thanks,
Shyam.
