Hi.
I can install Volumio 3 Beta in Raspberry Pi CM4 and works fine.
But I would like to install the stable release Volumio 2.x and have the plugin support in CM4.
I’m using eMMC and WiFi.
Do you know if there is a change to do this?
Thank you and best regards.
