My System: volumio-2.001-2016-10-15-pi on 8G SD-card, Raspi 1 Bplus, HiFiBerry DAC+
Volumio2 runs fine on IP-Radio as well as files on an USB stick - sound is excellent.
I started the installation (as user volumio; PW: volumio) of the spotify plugin included in the release which it ran w/o problems and ended with the message: “successfully installed”.
I filled in User and PW but the plugin would not signal activation. I ran update w/o success and after that I clicked “uninstall” which showed absolutely no reaction. Reboot etc. did not change things.
Please give me either some advice for troubleshooting or manual removal of this plugin.
hi,
I already noticed and reported that : something is wrong with dependencies. If you enter
spopd -c /etc/spopd.conf
you get spopd -c /etc/spopd.conf
spopd: error while loading shared libraries: libspotify.so.12: cannot open shared object file: No such file or directory
issue : https://github.com/volumio/volumio-plugins/issues/25
This on rpi B. Seems to work on RPI 2 and >
I got it activated, but when I play music from Spotify, there is no sound on the output. Radio for example works. Any ideas?
My config: RPI3+i2s iqaudio digiamp+, fresh installation of volumio 2.001 with spotify enabled, configured and activated + fix for config save. Tried twice, got the same issue.
Good news, now it is working. There are two issues:
1.) you have to add the correct LD_LIBRARY_PATH, you can also make by adding into /etc/environment the following, which will make it to set the variable on boot:
LD_LIBRARY_PATH="/usr/local/lib/"
2.) After investigating what is going on, i noticed, that servis spopd is reporting wrong username. I change the userneme not to use the “@” symbol. Now it is working.
