I’m trying to build Volumio for the Orange Pi PC which is a sun8i device and has an Alwinner H3 chip. But I haven’t had any luck getting it to boot so far.
What I did is I cloned the Volumio_Build repo to my bitbucket and made some changes which you can find here bitbucket.org/throwbin/volumio_orangepipc/src. Basically what I did is I edited the armbian configuration files a bit to work with my device.
After the changes when I build the image from my bitbucket repo I did manage to get the device to do something, the green LED on the boards lights up and if I connect a LAN cable the activity indicator blinks (Green LED on LAN port) but I don’t get any HDMI output on my screen nor do I find the device on my network.
I made this thread because maybe someone with more expertise on this forum can correct my mistakes. So I can hopefully get a working build.
Here is my log from my Terminal trying to make the image, my build environment is Ubuntu 16.04.2 LTS.
gianni@ubuntu:~/volumio_orangepipc$ sudo ./build.sh -d armbian_orangepipc_legacy -v 2.0
Checking whether we are running as root
Writing image for Orange Pi PC
BOARD:orangepipc BRANCH:legacy
Creating Image File Volumio2.0-2017-07-11-armbian_orangepipc_legacy.img with Debian 32bit rootfs
2800+0 records in
2800+0 records out
2936012800 bytes (2.9 GB, 2.7 GiB) copied, 5.34987 s, 549 MB/s
Creating Image Bed
Model: Loopback device (loopback)
Disk /dev/loop0: 2936MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 64.0MB 62.9MB primary boot
2 65.0MB 2500MB 2435MB primary
3 2500MB 2936MB 436MB primary
Using: /dev/mapper/loop0p1
Using: /dev/mapper/loop0p2
Using: /dev/mapper/loop0p3
Creating boot and rootfs filesystems
mke2fs 1.42.13 (17-May-2015)
Discarding device blocks: done
Creating filesystem with 61440 1k blocks and 15360 inodes
Filesystem UUID: 7a09a430-244c-4741-afd6-3e4859b0b4f9
Superblock backups stored on blocks:
8193, 24577, 40961, 57345
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
Creating filesystem with 594432 4k blocks and 148656 inodes
Filesystem UUID: 75a2d8b5-aeca-42b1-9fef-934753714720
32768, 98304, 163840, 229376, 294912
Creating journal (16384 blocks): done
Creating filesystem with 425984 1k blocks and 106496 inodes
Filesystem UUID: 7add62d8-a4db-40e9-993c-86a2c3375e90
8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409
Creating journal (8192 blocks): done
/mount folder exist
Creating Volumio Temp Directory
Creating mount point for the images partition
Creating mount point for the boot partition
Copying Volumio RootFs
Preparing to run chroot for more Orange PI PC configuration
--2017-07-11 05:04:32-- http://repo.volumio.org/Volumio2/Binaries/volumio-init-updater
Resolving repo.volumio.org (repo.volumio.org)... 188.226.147.229
Connecting to repo.volumio.org (repo.volumio.org)|188.226.147.229|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7400 (7.2K) [application/octet-stream]
Saving to: ‘/mnt/volumio/rootfs/root/volumio-init-updater’
volumio-init-updater 100%[=================================>] 7.23K --.-KB/s in 0s
2017-07-11 05:04:32 (424 MB/s) - ‘/mnt/volumio/rootfs/root/volumio-init-updater’ saved [7400/7400]
+ su -
++ cat /patch
+ PATCH=volumio
+ echo 'Creating "fstab"'
Creating "fstab"
+ echo '# BPI-PRO fstab'
+ echo ''
+ echo 'proc /proc proc defaults 0 0
# /dev/mmcblk0p1 /boot vfat defaults,utf8,user,rw,umask=111,dmask=000 0 1
/dev/mmcblk0p1 /boot ext4 defaults
tmpfs /var/log tmpfs size=20M,nodev,uid=1000,mode=0777,gid=4, 0 0
tmpfs /var/spool/cups tmpfs defaults,noatime,mode=0755 0 0
tmpfs /var/spool/cups/tmp tmpfs defaults,noatime,mode=0755 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=0755 0 0
tmpfs /dev/shm tmpfs defaults,nosuid,noexec,nodev 0 0
+ apt-get update
Ign http://ftp.nl.debian.org jessie InRelease
Get:1 http://ftp.nl.debian.org jessie Release.gpg [2373 B]
Get:2 http://ftp.nl.debian.org jessie Release [148 kB]
Get:3 http://ftp.nl.debian.org jessie/main Sources [7055 kB]
Get:4 http://ftp.nl.debian.org jessie/contrib Sources [50.8 kB]
Get:5 http://ftp.nl.debian.org jessie/non-free Sources [99.5 kB]
Get:6 http://ftp.nl.debian.org jessie/main armhf Packages [6645 kB]
Get:7 http://ftp.nl.debian.org jessie/contrib armhf Packages [38.1 kB]
Get:8 http://ftp.nl.debian.org jessie/non-free armhf Packages [62.5 kB]
Get:9 http://ftp.nl.debian.org jessie/contrib Translation-en [38.5 kB]
Get:10 http://ftp.nl.debian.org jessie/main Translation-en [4583 kB]
Get:11 http://ftp.nl.debian.org jessie/non-free Translation-en [72.1 kB]
Fetched 18.8 MB in 31s (597 kB/s)
Reading package lists... Done
+ apt-get -y install u-boot-tools liblircclient0 lirc aptitude bc
Building dependency tree... Done
The following extra packages will be installed:
aptitude-common aptitude-doc-en libboost-iostreams1.55.0 libclass-accessor-perl libcwidget3
libftdi1 libio-string-perl libparse-debianchangelog-perl libsigc++-2.0-0c2a libsub-name-perl
libtimedate-perl libxapian22
Suggested packages:
tasksel debtags apt-xapian-index libcwidget-dev libhtml-parser-perl libhtml-template-perl
libxml-simple-perl xapian-tools lirc-x setserial ir-keytable
The following NEW packages will be installed:
aptitude aptitude-common aptitude-doc-en bc libboost-iostreams1.55.0 libclass-accessor-perl
libcwidget3 libftdi1 libio-string-perl liblircclient0 libparse-debianchangelog-perl
libsigc++-2.0-0c2a libsub-name-perl libtimedate-perl libxapian22 lirc u-boot-tools
0 upgraded, 17 newly installed, 0 to remove and 0 not upgraded.
Need to get 5323 kB of archives.
After this operation, 20.7 MB of additional disk space will be used.
Get:1 http://ftp.nl.debian.org/debian/ jessie/main libboost-iostreams1.55.0 armhf 1.55.0+dfsg-3 [47.3 kB]
Get:2 http://ftp.nl.debian.org/debian/ jessie/main libsigc++-2.0-0c2a armhf 2.4.0-1 [49.7 kB]
Get:3 http://ftp.nl.debian.org/debian/ jessie/main libcwidget3 armhf 0.5.17-2 [302 kB]
Get:4 http://ftp.nl.debian.org/debian/ jessie/main libftdi1 armhf 0.20-2 [17.0 kB]
Get:5 http://ftp.nl.debian.org/debian/ jessie/main aptitude-common all 0.6.11-1 [1576 kB]
Get:6 http://ftp.nl.debian.org/debian/ jessie/main libxapian22 armhf 1.2.19-1+deb8u1 [887 kB]
Get:7 http://ftp.nl.debian.org/debian/ jessie/main aptitude armhf 0.6.11-1+b1 [1327 kB]
Get:8 http://ftp.nl.debian.org/debian/ jessie/main bc armhf 1.06.95-9 [96.4 kB]
Get:9 http://ftp.nl.debian.org/debian/ jessie/main aptitude-doc-en all 0.6.11-1 [419 kB]
Get:10 http://ftp.nl.debian.org/debian/ jessie/main libsub-name-perl armhf 0.12-1 [11.7 kB]
Get:11 http://ftp.nl.debian.org/debian/ jessie/main libclass-accessor-perl all 0.34-1 [25.9 kB]
Get:12 http://ftp.nl.debian.org/debian/ jessie/main libio-string-perl all 1.08-3 [12.3 kB]
Get:13 http://ftp.nl.debian.org/debian/ jessie/main liblircclient0 armhf 0.9.0~pre1-1.2 [33.0 kB]
Get:14 http://ftp.nl.debian.org/debian/ jessie/main libtimedate-perl all 2.3000-2 [42.2 kB]
Get:15 http://ftp.nl.debian.org/debian/ jessie/main libparse-debianchangelog-perl all 1.2.0-1.1 [57.9 kB]
Get:16 http://ftp.nl.debian.org/debian/ jessie/main u-boot-tools armhf 2014.10+dfsg1-5 [70.3 kB]
Get:17 http://ftp.nl.debian.org/debian/ jessie/main lirc armhf 0.9.0~pre1-1.2 [348 kB]
Fetched 5323 kB in 2s (2283 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device)
Selecting previously unselected package libboost-iostreams1.55.0:armhf.
(Reading database ... 18880 files and directories currently installed.)
Preparing to unpack .../libboost-iostreams1.55.0_1.55.0+dfsg-3_armhf.deb ...
Unpacking libboost-iostreams1.55.0:armhf (1.55.0+dfsg-3) ...
Selecting previously unselected package libsigc++-2.0-0c2a:armhf.
Preparing to unpack .../libsigc++-2.0-0c2a_2.4.0-1_armhf.deb ...
Unpacking libsigc++-2.0-0c2a:armhf (2.4.0-1) ...
Selecting previously unselected package libcwidget3:armhf.
Preparing to unpack .../libcwidget3_0.5.17-2_armhf.deb ...
Unpacking libcwidget3:armhf (0.5.17-2) ...
Selecting previously unselected package libftdi1:armhf.
Preparing to unpack .../libftdi1_0.20-2_armhf.deb ...
Unpacking libftdi1:armhf (0.20-2) ...
Selecting previously unselected package aptitude-common.
Preparing to unpack .../aptitude-common_0.6.11-1_all.deb ...
Unpacking aptitude-common (0.6.11-1) ...
Selecting previously unselected package libxapian22.
Preparing to unpack .../libxapian22_1.2.19-1+deb8u1_armhf.deb ...
Unpacking libxapian22 (1.2.19-1+deb8u1) ...
Selecting previously unselected package aptitude.
Preparing to unpack .../aptitude_0.6.11-1+b1_armhf.deb ...
Unpacking aptitude (0.6.11-1+b1) ...
Selecting previously unselected package bc.
Preparing to unpack .../bc_1.06.95-9_armhf.deb ...
Unpacking bc (1.06.95-9) ...
Selecting previously unselected package aptitude-doc-en.
Preparing to unpack .../aptitude-doc-en_0.6.11-1_all.deb ...
Unpacking aptitude-doc-en (0.6.11-1) ...
Selecting previously unselected package libsub-name-perl.
Preparing to unpack .../libsub-name-perl_0.12-1_armhf.deb ...
Unpacking libsub-name-perl (0.12-1) ...
Selecting previously unselected package libclass-accessor-perl.
Preparing to unpack .../libclass-accessor-perl_0.34-1_all.deb ...
Unpacking libclass-accessor-perl (0.34-1) ...
Selecting previously unselected package libio-string-perl.
Preparing to unpack .../libio-string-perl_1.08-3_all.deb ...
Unpacking libio-string-perl (1.08-3) ...
Selecting previously unselected package liblircclient0.
Preparing to unpack .../liblircclient0_0.9.0~pre1-1.2_armhf.deb ...
Unpacking liblircclient0 (0.9.0~pre1-1.2) ...
Selecting previously unselected package libtimedate-perl.
Preparing to unpack .../libtimedate-perl_2.3000-2_all.deb ...
Unpacking libtimedate-perl (2.3000-2) ...
Selecting previously unselected package libparse-debianchangelog-perl.
Preparing to unpack .../libparse-debianchangelog-perl_1.2.0-1.1_all.deb ...
Unpacking libparse-debianchangelog-perl (1.2.0-1.1) ...
Selecting previously unselected package u-boot-tools.
Preparing to unpack .../u-boot-tools_2014.10+dfsg1-5_armhf.deb ...
Unpacking u-boot-tools (2014.10+dfsg1-5) ...
Selecting previously unselected package lirc.
Preparing to unpack .../lirc_0.9.0~pre1-1.2_armhf.deb ...
Unpacking lirc (0.9.0~pre1-1.2) ...
Processing triggers for systemd (215-17+deb8u7) ...
Setting up libboost-iostreams1.55.0:armhf (1.55.0+dfsg-3) ...
Setting up libsigc++-2.0-0c2a:armhf (2.4.0-1) ...
Setting up libcwidget3:armhf (0.5.17-2) ...
Setting up libftdi1:armhf (0.20-2) ...
Setting up aptitude-common (0.6.11-1) ...
Setting up libxapian22 (1.2.19-1+deb8u1) ...
Setting up aptitude (0.6.11-1+b1) ...
update-alternatives: using /usr/bin/aptitude-curses to provide /usr/bin/aptitude (aptitude) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/cs/man8/aptitude.8.gz because associated file /usr/share/man/cs/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/de/man8/aptitude.8.gz because associated file /usr/share/man/de/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/es/man8/aptitude.8.gz because associated file /usr/share/man/es/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fi/man8/aptitude.8.gz because associated file /usr/share/man/fi/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/fr/man8/aptitude.8.gz because associated file /usr/share/man/fr/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/gl/man8/aptitude.8.gz because associated file /usr/share/man/gl/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/it/man8/aptitude.8.gz because associated file /usr/share/man/it/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/ja/man8/aptitude.8.gz because associated file /usr/share/man/ja/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
update-alternatives: warning: skip creation of /usr/share/man/pl/man8/aptitude.8.gz because associated file /usr/share/man/pl/man8/aptitude-curses.8.gz (of link group aptitude) doesn't exist
Setting up bc (1.06.95-9) ...
Setting up aptitude-doc-en (0.6.11-1) ...
Setting up libsub-name-perl (0.12-1) ...
Setting up libclass-accessor-perl (0.34-1) ...
Setting up libio-string-perl (1.08-3) ...
Setting up liblircclient0 (0.9.0~pre1-1.2) ...
Setting up libtimedate-perl (2.3000-2) ...
Setting up libparse-debianchangelog-perl (1.2.0-1.1) ...
Setting up u-boot-tools (2014.10+dfsg1-5) ...
Setting up lirc (0.9.0~pre1-1.2) ...
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for libc-bin (2.19-18+deb8u9) ...
+ echo 'Installing additonal packages'
+ . /root/upgrade_armbian.sh
++ set -x
++ . /root/device.sh
+++ BOARD=orangepipc
+++ BRANCH=legacy
++ BOARD=orangepipc
++ RELEASE=jessie
++ HARDWARE=sun8i
++ [[ jessie == \s\i\d ]]
++ [[ jessie == \t\e\s\t\i\n\g ]]
++ backtitle='Armbian install script, http://www.armbian.com | Author: Igor Pecovnik'
++ title='Armbian universal installer'
++ [[ 0 -ne 0 ]]
++ display_warning
++ read -r -d '' MOJTEXT
++ install_repo
++ echo title 'Armbian universal installer' backtitle 'Armbian install script, http://www.armbian.com | Author: Igor Pecovnik' infobox '\nAdding repository and running pkg list update.' 5 50
title Armbian universal installer backtitle Armbian install script, http://www.armbian.com | Author: Igor Pecovnik infobox \nAdding repository and running pkg list update. 5 50
++ apt-get -f -qq install
++ apt-get clean
++ apt-get -y -qq remove hostapd
(Reading database ... 19672 files and directories currently installed.)
Removing hostapd (1:2.3-1+deb8u4) ...
invoke-rc.d: policy-rc.d denied execution of stop.
++ '[' 0 -ne 0 ']'
++ sed -i /armbian/d /etc/apt/sources.list
++ '[' -f /etc/apt/sources.list.d/bananian.list ']'
++ '[' '!' -f /etc/apt/sources.list.d/armbian.list ']'
++ echo -e '[\e[0;32m o.k. \x1B[0m] Updating package list. Please wait'
[ o.k. ] Updating package list. Please wait
++ echo 'deb http://apt.armbian.com jessie main'
++ apt-key adv --keyserver keys.gnupg.net --recv-keys 0x93D6889F9F0E78D5
++ apt-get update
++ create_boot_script
++ '[' -f /boot/boot.cmd ']'
++ cat
++ mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
++ select_boards
++ '[' -z orangepipc ']'
++ '[' orangepipc == '' ']'
++ '[' -z legacy ']'
++ '[' legacy == '' ']'
++ [[ legacy == \v\a\n\i\l\l\a ]]
++ ROOT_BRACH=
++ ROOTBRACH2=-default
++ case $BOARD in
++ LINUXFAMILY=sun8i
++ [[ orangepipc == \c\u\b\o\x\-\i ]]
++ [[ orangepipc == udoo* ]]
++ PACKETS='linux-image-sun8i linux-firmware-image-sun8i linux-u-boot-orangepipc-default=5.23 linux-headers-sun8i linux-jessie-root-orangepipc '
++ install_new -d 'Downloading packages...'
++ IFS=' '
++ apt-get -d -o Dpkg::Options::=--force-overwrite -y install linux-image-sun8i linux-firmware-image-sun8i linux-u-boot-orangepipc-default=5.23 linux-headers-sun8i linux-jessie-root-orangepipc
Reading state information... Done
dh-python iso-codes libapt-inst1.5 libmpdec2 libpython3-stdlib libpython3.4-minimal
libpython3.4-stdlib libuuid-perl linux-base lsb-release python-apt-common python3 python3-apt
python3-minimal python3.4 python3.4-minimal toilet toilet-fonts
Suggested packages:
isoquery lsb python3-doc python3-tk python3-venv python3-apt-dbg python-apt-doc python3.4-venv
python3.4-doc binutils binfmt-support figlet
libpython3.4-stdlib libuuid-perl linux-base linux-firmware-image-sun8i linux-headers-sun8i
linux-image-sun8i linux-jessie-root-orangepipc linux-u-boot-orangepipc-default lsb-release
python-apt-common python3 python3-apt python3-minimal python3.4 python3.4-minimal toilet
toilet-fonts
0 upgraded, 23 newly installed, 0 to remove and 0 not upgraded.
Need to get 26.8 MB of archives.
After this operation, 123 MB of additional disk space will be used.
Get:1 http://ftp.nl.debian.org/debian/ jessie/main libapt-inst1.5 armhf 1.0.9.8.4 [167 kB]
Get:2 http://apt.armbian.com/ jessie/main linux-firmware-image-sun8i armhf 5.31 [112 kB]
Get:3 http://ftp.nl.debian.org/debian/ jessie/main libmpdec2 armhf 2.4.1-1 [70.7 kB]
Get:4 http://ftp.nl.debian.org/debian/ jessie/main libpython3.4-minimal armhf 3.4.2-1 [485 kB]
Get:5 http://apt.armbian.com/ jessie/main linux-headers-sun8i armhf 5.31 [5774 kB]
Get:6 http://ftp.nl.debian.org/debian/ jessie/main libpython3.4-stdlib armhf 3.4.2-1 [2011 kB]
Get:7 http://ftp.nl.debian.org/debian/ jessie/main python3.4-minimal armhf 3.4.2-1 [1364 kB]
Get:8 http://ftp.nl.debian.org/debian/ jessie/main python3.4 armhf 3.4.2-1 [204 kB]
Get:9 http://ftp.nl.debian.org/debian/ jessie/main python3-minimal armhf 3.4.2-2 [34.6 kB]
Get:10 http://ftp.nl.debian.org/debian/ jessie/main libpython3-stdlib armhf 3.4.2-2 [18.1 kB]
Get:11 http://ftp.nl.debian.org/debian/ jessie/main python3 armhf 3.4.2-2 [21.2 kB]
Get:12 http://ftp.nl.debian.org/debian/ jessie/main dh-python all 1.20141111-2 [66.4 kB]
Get:13 http://ftp.nl.debian.org/debian/ jessie/main iso-codes all 3.57-1 [2265 kB]
Get:14 http://ftp.nl.debian.org/debian/ jessie/main libuuid-perl armhf 0.05-1+b1 [10.0 kB]
Get:15 http://ftp.nl.debian.org/debian/ jessie/main linux-base all 3.5 [34.3 kB]
Get:16 http://ftp.nl.debian.org/debian/ jessie/main lsb-release all 4.1+Debian13+nmu1 [26.5 kB]
Get:17 http://ftp.nl.debian.org/debian/ jessie/main python-apt-common all 0.9.3.12 [89.9 kB]
Get:18 http://ftp.nl.debian.org/debian/ jessie/main python3-apt armhf 0.9.3.12 [156 kB]
Get:19 http://ftp.nl.debian.org/debian/ jessie/main toilet-fonts all 0.3-1 [731 kB]
Get:20 http://ftp.nl.debian.org/debian/ jessie/main toilet armhf 0.3-1 [21.7 kB]
Get:21 http://apt.armbian.com/ jessie/main linux-image-sun8i armhf 5.31 [12.6 MB]
Get:22 http://apt.armbian.com/ jessie/main linux-jessie-root-orangepipc armhf 5.31 [395 kB]
Get:23 http://apt.armbian.com/ jessie/main linux-u-boot-orangepipc-default armhf 5.23 [157 kB]
Fetched 26.8 MB in 28s (946 kB/s)
Download complete and in download only mode
++ '[' 0 -ne 0 ']'
++ remove_old
++ echo title 'Armbian universal installer' backtitle 'Armbian install script, http://www.armbian.com | Author: Igor Pecovnik' infobox '\nRemoving conflicting packages ...' 5 41
title Armbian universal installer backtitle Armbian install script, http://www.armbian.com | Author: Igor Pecovnik infobox \nRemoving conflicting packages ... 5 41
++ aptitude remove '~nlinux-dtb' --quiet=100
++ aptitude remove '~nlinux-u-boot' --quiet=100
++ aptitude remove '~nlinux-image' --quiet=100
++ aptitude remove '~nlinux-headers' --quiet=100
++ aptitude remove '~nlinux-firmware' --quiet=100
++ aptitude remove '~nlinux-jessie-root' --quiet=100
++ install_new '' 'Installing packages...'
++ IFS=' '
++ apt-get -o Dpkg::Options::=--force-overwrite -y install linux-image-sun8i linux-firmware-image-sun8i linux-u-boot-orangepipc-default=5.23 linux-headers-sun8i linux-jessie-root-orangepipc
Suggested packages:
toilet-fonts
Need to get 0 B/26.8 MB of archives.
Selecting previously unselected package libapt-inst1.5:armhf.
(Reading database ... 19652 files and directories currently installed.)
Preparing to unpack .../libapt-inst1.5_1.0.9.8.4_armhf.deb ...
Unpacking libapt-inst1.5:armhf (1.0.9.8.4) ...
Selecting previously unselected package libmpdec2:armhf.
Preparing to unpack .../libmpdec2_2.4.1-1_armhf.deb ...
Unpacking libmpdec2:armhf (2.4.1-1) ...
Selecting previously unselected package libpython3.4-minimal:armhf.
Preparing to unpack .../libpython3.4-minimal_3.4.2-1_armhf.deb ...
Unpacking libpython3.4-minimal:armhf (3.4.2-1) ...
Selecting previously unselected package libpython3.4-stdlib:armhf.
Preparing to unpack .../libpython3.4-stdlib_3.4.2-1_armhf.deb ...
Unpacking libpython3.4-stdlib:armhf (3.4.2-1) ...
Selecting previously unselected package python3.4-minimal.
Preparing to unpack .../python3.4-minimal_3.4.2-1_armhf.deb ...
Unpacking python3.4-minimal (3.4.2-1) ...
Selecting previously unselected package python3.4.
Preparing to unpack .../python3.4_3.4.2-1_armhf.deb ...
Unpacking python3.4 (3.4.2-1) ...
Selecting previously unselected package python3-minimal.
Preparing to unpack .../python3-minimal_3.4.2-2_armhf.deb ...
Unpacking python3-minimal (3.4.2-2) ...
Selecting previously unselected package libpython3-stdlib:armhf.
Preparing to unpack .../libpython3-stdlib_3.4.2-2_armhf.deb ...
Unpacking libpython3-stdlib:armhf (3.4.2-2) ...
Preparing to unpack .../python3_3.4.2-2_armhf.deb ...
Unpacking python3 (3.4.2-2) ...
Selecting previously unselected package dh-python.
Preparing to unpack .../dh-python_1.20141111-2_all.deb ...
Unpacking dh-python (1.20141111-2) ...
Selecting previously unselected package iso-codes.
Preparing to unpack .../iso-codes_3.57-1_all.deb ...
Unpacking iso-codes (3.57-1) ...
Selecting previously unselected package libuuid-perl.
Preparing to unpack .../libuuid-perl_0.05-1+b1_armhf.deb ...
Unpacking libuuid-perl (0.05-1+b1) ...
Selecting previously unselected package linux-base.
Preparing to unpack .../linux-base_3.5_all.deb ...
Unpacking linux-base (3.5) ...
Selecting previously unselected package linux-firmware-image-sun8i.
Preparing to unpack .../linux-firmware-image-sun8i_5.31_armhf.deb ...
Unpacking linux-firmware-image-sun8i (5.31) ...
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: trying to overwrite '/lib/firmware/keyspan_pda/xircom_pgs.fw', which is also in package firmware-linux-free 3.3
dpkg: warning: trying to overwrite '/lib/firmware/keyspan_pda/keyspan_pda.fw', which is also in package firmware-linux-free 3.3
Selecting previously unselected package linux-headers-sun8i.
Preparing to unpack .../linux-headers-sun8i_5.31_armhf.deb ...
Unpacking linux-headers-sun8i (5.31) ...
Selecting previously unselected package linux-image-sun8i.
Preparing to unpack .../linux-image-sun8i_5.31_armhf.deb ...
Unpacking linux-image-sun8i (5.31) ...
Selecting previously unselected package linux-jessie-root-orangepipc.
Preparing to unpack .../linux-jessie-root-orangepipc_5.31_armhf.deb ...
Adding 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-orangepipc'
Unpacking linux-jessie-root-orangepipc (5.31) ...
Selecting previously unselected package linux-u-boot-orangepipc-default.
Preparing to unpack .../linux-u-boot-orangepipc-default_5.23_armhf.deb ...
Unpacking linux-u-boot-orangepipc-default (5.23) ...
Selecting previously unselected package lsb-release.
Preparing to unpack .../lsb-release_4.1+Debian13+nmu1_all.deb ...
Unpacking lsb-release (4.1+Debian13+nmu1) ...
Selecting previously unselected package python-apt-common.
Preparing to unpack .../python-apt-common_0.9.3.12_all.deb ...
Unpacking python-apt-common (0.9.3.12) ...
Selecting previously unselected package python3-apt.
Preparing to unpack .../python3-apt_0.9.3.12_armhf.deb ...
Unpacking python3-apt (0.9.3.12) ...
Selecting previously unselected package toilet-fonts.
Preparing to unpack .../toilet-fonts_0.3-1_all.deb ...
Unpacking toilet-fonts (0.3-1) ...
Selecting previously unselected package toilet.
Preparing to unpack .../toilet_0.3-1_armhf.deb ...
Unpacking toilet (0.3-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for initramfs-tools (0.120+deb8u3) ...
Setting up libapt-inst1.5:armhf (1.0.9.8.4) ...
Setting up libmpdec2:armhf (2.4.1-1) ...
Setting up libpython3.4-minimal:armhf (3.4.2-1) ...
Setting up libpython3.4-stdlib:armhf (3.4.2-1) ...
Setting up python3.4-minimal (3.4.2-1) ...
Setting up python3.4 (3.4.2-1) ...
Setting up python3-minimal (3.4.2-2) ...
Setting up libpython3-stdlib:armhf (3.4.2-2) ...
Setting up iso-codes (3.57-1) ...
Setting up libuuid-perl (0.05-1+b1) ...
Setting up linux-base (3.5) ...
Setting up linux-firmware-image-sun8i (5.31) ...
Setting up linux-headers-sun8i (5.31) ...
Compiling headers - please wait ...
Setting up linux-image-sun8i (5.31) ...
update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i
Unsupported ioctl: cmd=0x5331
update-initramfs: Converting to u-boot format
Setting up linux-jessie-root-orangepipc (5.31) ...
Setting up linux-u-boot-orangepipc-default (5.23) ...
Updating u-boot on device /dev/mmcblk0
Setting up lsb-release (4.1+Debian13+nmu1) ...
Setting up python-apt-common (0.9.3.12) ...
Setting up toilet-fonts (0.3-1) ...
Setting up toilet (0.3-1) ...
update-alternatives: using /usr/bin/figlet-toilet to provide /usr/bin/figlet (figlet) in auto mode
Setting up dh-python (1.20141111-2) ...
Setting up python3 (3.4.2-2) ...
running python rtupdate hooks for python3.4...
running python post-rtupdate hooks for python3.4...
Setting up python3-apt (0.9.3.12) ...
++ '[' 0 -ne 0 ']'
++ copy_boot0
+++ find /usr/lib/
+++ grep u-boot-sunxi-with-spl.bin
++ DIR=/usr/lib/linux-u-boot-orangepipc_5.23_armhf/u-boot-sunxi-with-spl.bin
++ '[' -f /usr/lib/linux-u-boot-orangepipc_5.23_armhf/u-boot-sunxi-with-spl.bin ']'
++ cp /usr/lib/linux-u-boot-orangepipc_5.23_armhf/u-boot-sunxi-with-spl.bin /boot
++ echo title 'Armbian universal installer' backtitle 'Armbian install script, http://www.armbian.com | Author: Igor Pecovnik' progressbox 'System upgrade' 20 80
title Armbian universal installer backtitle Armbian install script, http://www.armbian.com | Author: Igor Pecovnik progressbox System upgrade 20 80
++ echo 'All done\nVisit: forum.armbian.com in case of troubles or just for fun ;)'
++ echo ''
+ echo 'Adding custom modules overlayfs, squashfs and nls_cp437'
+ echo overlay
+ echo overlayfs
+ echo squashfs
+ echo nls_cp437
+ echo 'Copying volumio initramfs updater'
+ cd /root/
+ mv volumio-init-updater /usr/local/sbin
+ '[' volumio = volumio ']'
+ echo 'No Patch To Apply'
No Patch To Apply
+ rm /patch
+ echo 'Installing winbind here, since it freezes networking'
+ apt-get update
Hit http://ftp.nl.debian.org jessie Release.gpg
Hit http://apt.armbian.com jessie InRelease
Hit http://ftp.nl.debian.org jessie/main Sources
Hit http://ftp.nl.debian.org jessie/contrib Sources
Hit http://ftp.nl.debian.org jessie/non-free Sources
Hit http://apt.armbian.com jessie/main armhf Packages
Hit http://ftp.nl.debian.org jessie/main armhf Packages
Hit http://ftp.nl.debian.org jessie/contrib armhf Packages
Hit http://ftp.nl.debian.org jessie/non-free armhf Packages
Hit http://ftp.nl.debian.org jessie/contrib Translation-en
Hit http://ftp.nl.debian.org jessie/main Translation-en
Hit http://ftp.nl.debian.org jessie/non-free Translation-en
Ign http://apt.armbian.com jessie/main Translation-en
+ apt-get install -y winbind libnss-winbind
Suggested packages:
libpam-winbind
libnss-winbind winbind
0 upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
Need to get 560 kB of archives.
After this operation, 1374 kB of additional disk space will be used.
Get:1 http://ftp.nl.debian.org/debian/ jessie/main winbind armhf 2:4.2.14+dfsg-0+deb8u5 [453 kB]
Get:2 http://ftp.nl.debian.org/debian/ jessie/main libnss-winbind armhf 2:4.2.14+dfsg-0+deb8u5 [106 kB]
Fetched 560 kB in 0s (1169 kB/s)
Selecting previously unselected package winbind.
(Reading database ... 35601 files and directories currently installed.)
Preparing to unpack .../winbind_2%3a4.2.14+dfsg-0+deb8u5_armhf.deb ...
Unpacking winbind (2:4.2.14+dfsg-0+deb8u5) ...
Selecting previously unselected package libnss-winbind:armhf.
Preparing to unpack .../libnss-winbind_2%3a4.2.14+dfsg-0+deb8u5_armhf.deb ...
Unpacking libnss-winbind:armhf (2:4.2.14+dfsg-0+deb8u5) ...
Setting up winbind (2:4.2.14+dfsg-0+deb8u5) ...
Setting up libnss-winbind:armhf (2:4.2.14+dfsg-0+deb8u5) ...
+ echo 'Cleaning APT Cache and remove policy file'
+ rm -f '/var/lib/apt/lists/*archive*'
+ apt-get clean
+ rm /usr/sbin/policy-rc.d
+ echo 'Changing to '\''modules=most'\'''
Changing to 'modules=most'
+ echo 'Signalling the init script to re-size the volumio data partition'
+ touch /boot/resize-volumio-datapart
+ echo 'Creating initramfs '\''volumio.initrd'\'''
Creating initramfs 'volumio.initrd'
+ mkinitramfs-custom.sh -o /tmp/initramfs-tmp
Version: 3.4.113-sun8i
Adding findfs/ parted/ mkfs.ext4/ e2fsck to initramfs
Adding all common dependencies
Adding volumio-init-updater to initramfs
Creating initrd image
./lib
./lib/klibc-sKNr1Fw-Rh9G1FYpGCXRnrwmP2A.so
./lib/libnss_files-2.19.so
./lib/udev
./lib/udev/ata_id
./lib/udev/rules.d
./lib/udev/rules.d/80-drivers.rules
./lib/udev/rules.d/55-dm.rules
./lib/udev/rules.d/50-udev-default.rules
./lib/udev/rules.d/50-firmware.rules
./lib/udev/rules.d/60-persistent-storage-dm.rules
./lib/udev/rules.d/60-persistent-storage.rules
./lib/udev/hotplug.functions
./lib/udev/scsi_id
./lib/ld-linux-armhf.so.3
./lib/systemd
./lib/systemd/systemd-udevd
./lib/modprobe.d
./lib/modprobe.d/aliases.conf
./lib/modules
./lib/modules/3.4.113-sun8i
./lib/modules/3.4.113-sun8i/modules.alias.bin
./lib/modules/3.4.113-sun8i/modules.order
./lib/modules/3.4.113-sun8i/modules.dep.bin
./lib/modules/3.4.113-sun8i/modules.softdep
./lib/modules/3.4.113-sun8i/kernel
./lib/modules/3.4.113-sun8i/kernel/net
./lib/modules/3.4.113-sun8i/kernel/net/ipv4
./lib/modules/3.4.113-sun8i/kernel/net/ipv4/gre.ko
./lib/modules/3.4.113-sun8i/kernel/drivers
./lib/modules/3.4.113-sun8i/kernel/drivers/i2c
./lib/modules/3.4.113-sun8i/kernel/drivers/i2c/muxes
./lib/modules/3.4.113-sun8i/kernel/drivers/i2c/muxes/pca9541.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/i2c/muxes/pca954x.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/i2c/muxes/gpio-i2cmux.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/net
./lib/modules/3.4.113-sun8i/kernel/drivers/net/ppp
./lib/modules/3.4.113-sun8i/kernel/drivers/net/ppp/pptp.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/scsi_wait_scan.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/libiscsi_tcp.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/iscsi_tcp.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/scsi_transport_iscsi.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/libiscsi.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/scsi/iscsi_boot_sysfs.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-roccat-common.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-roccat-isku.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-logitech-dj.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-roccat.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-ortek.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-samsung.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-primax.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-roccat-arvo.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-sunplus.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-sjoy.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-topseed.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-keytouch.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-xinmo.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/hid/hid-prodikeys.ko
./lib/modules/3.4.113-sun8i/kernel/drivers/gpio
./lib/modules/3.4.113-sun8i/kernel/drivers/gpio/gpio-sunxi.ko
./lib/modules/3.4.113-sun8i/kernel/fs
./lib/modules/3.4.113-sun8i/kernel/fs/xfs
./lib/modules/3.4.113-sun8i/kernel/fs/xfs/xfs.ko
./lib/modules/3.4.113-sun8i/kernel/fs/btrfs
./lib/modules/3.4.113-sun8i/kernel/fs/btrfs/btrfs.ko
./lib/modules/3.4.113-sun8i/modules.symbols.bin
./lib/modules/3.4.113-sun8i/modules.builtin.bin
./lib/modules/3.4.113-sun8i/modules.devname
./lib/libnss_files.so.2
./lib/arm-linux-gnueabihf
./lib/arm-linux-gnueabihf/libply.so.2
./lib/arm-linux-gnueabihf/libkmod.so.2
./lib/arm-linux-gnueabihf/librt.so.1
./lib/arm-linux-gnueabihf/libselinux.so.1
./lib/arm-linux-gnueabihf/libcom_err.so.2
./lib/arm-linux-gnueabihf/libpthread.so.0
./lib/arm-linux-gnueabihf/libc.so.6
./lib/arm-linux-gnueabihf/libparted.so.2
./lib/arm-linux-gnueabihf/libpcre.so.3
./lib/arm-linux-gnueabihf/libntfs-3g.so.852
./lib/arm-linux-gnueabihf/libdevmapper.so.1.02.1
./lib/arm-linux-gnueabihf/libreadline.so.6
./lib/arm-linux-gnueabihf/libtinfo.so.5
./lib/arm-linux-gnueabihf/libgcc_s.so.1
./lib/arm-linux-gnueabihf/libudev.so.1
./lib/arm-linux-gnueabihf/libe2p.so.2
./lib/arm-linux-gnueabihf/libacl.so.1
./lib/arm-linux-gnueabihf/libm.so.6
./lib/arm-linux-gnueabihf/libdl.so.2
./lib/arm-linux-gnueabihf/libcrypt.so.1
./lib/arm-linux-gnueabihf/libmount.so.1
./lib/arm-linux-gnueabihf/libblkid.so.1
./lib/arm-linux-gnueabihf/libext2fs.so.2
./lib/arm-linux-gnueabihf/libattr.so.1
./lib/arm-linux-gnueabihf/libuuid.so.1
./lib/arm-linux-gnueabihf/ld-linux.so.3
./lib/arm-linux-gnueabihf/libply-splash-core.so.2
./conf
./conf/arch.conf
./conf/conf.d
./conf/modules
./conf/initramfs.conf
./run
./sbin
./sbin/insmod
./sbin/rmmod
./sbin/swapon
./sbin/logread
./sbin/findfs
./sbin/loadfont
./sbin/depmod
./sbin/brctl
./sbin/mkswap
./sbin/logsave
./sbin/resize2fs
./sbin/freeramdisk
./sbin/switch_root
./sbin/syslogd
./sbin/getty
./sbin/halt
./sbin/reboot
./sbin/vconfig
./sbin/plymouthd
./sbin/fstrim
./sbin/e2fsck
./sbin/mount.ntfs
./sbin/sysctl
./sbin/loadkmap
./sbin/pivot_root
./sbin/fsck
./sbin/ip
./sbin/mkfs.ext4
./sbin/rdate
./sbin/udevadm
./sbin/mount.fuse
./sbin/blockdev
./sbin/modprobe
./sbin/lsmod
./sbin/swapoff
./sbin/udhcpc
./sbin/mount.ntfs-3g
./sbin/chroot
./sbin/poweroff
./sbin/sulogin
./sbin/hwclock
./sbin/partprobe
./sbin/devmem
./sbin/nameif
./sbin/watchdog
./sbin/modinfo
./sbin/init
./sbin/blkid
./sbin/acpid
./sbin/parted
./sbin/losetup
./sbin/ifconfig
./sbin/adjtimex
./sbin/arp
./sbin/arping
./sbin/mdev
./sbin/udhcpd
./sbin/start-stop-daemon
./sbin/volumio-init-updater
./sbin/httpd
./sbin/route
./sbin/klogd
./sbin/dmsetup
./usr
./usr/lib
./usr/lib/arm-linux-gnueabihf
./usr/lib/arm-linux-gnueabihf/plymouth
./usr/lib/arm-linux-gnueabihf/plymouth/renderers
./usr/lib/arm-linux-gnueabihf/plymouth/renderers/drm.so
./usr/lib/arm-linux-gnueabihf/plymouth/renderers/frame-buffer.so
./usr/lib/arm-linux-gnueabihf/plymouth/details.so
./usr/lib/arm-linux-gnueabihf/plymouth/text.so
./usr/lib/arm-linux-gnueabihf/libdrm.so.2
./usr/share
./usr/share/plymouth
./usr/share/plymouth/plymouthd.defaults
./usr/share/plymouth/themes
./usr/share/plymouth/themes/text
./usr/share/plymouth/themes/text/text.plymouth
./usr/share/plymouth/themes/details
./usr/share/plymouth/themes/details/details.plymouth
./etc
./etc/passwd
./etc/mtab
./etc/plymouth
./etc/plymouth/plymouthd.conf
./etc/ld.so.conf
./etc/udev
./etc/udev/udev.conf
./etc/os-release
./etc/nsswitch.conf
./etc/fstab
./etc/ld.so.cache
./etc/modprobe.d
./etc/modprobe.d/8192cu.conf
./etc/modprobe.d/fbdev-blacklist.conf
./etc/modprobe.d/alsa-base.conf
./etc/ld.so.conf.d
./etc/ld.so.conf.d/libc.conf
./etc/ld.so.conf.d/arm-linux-gnueabihf.conf
./etc/e2fsck.conf
./init
./bin
./bin/gzip
./bin/insmod
./bin/strings
./bin/logname
./bin/setsid
./bin/test
./bin/ln
./bin/diff
./bin/telnet
./bin/uudecode
./bin/tee
./bin/stat
./bin/true
./bin/tail
./bin/dos2unix
./bin/xz
./bin/dd
./bin/gunzip
./bin/bzip2
./bin/vi
./bin/plymouth
./bin/ar
./bin/pidof
./bin/umount
./bin/login
./bin/groups
./bin/rm
./bin/ls
./bin/tac
./bin/expand
./bin/unix2dos
./bin/nuke
./bin/which
./bin/mt
./bin/minips
./bin/less
./bin/dirname
./bin/cpio
./bin/tftp
./bin/cp
./bin/grep
./bin/traceroute6
./bin/reset
./bin/unxz
./bin/run-init
./bin/fold
./bin/ping6
./bin/wc
./bin/sh
./bin/hostid
./bin/resume
./bin/uniq
./bin/rev
./bin/unlzop
./bin/more
./bin/halt
./bin/reboot
./bin/taskset
./bin/killall
./bin/time
./bin/chmod
./bin/dumpleases
./bin/ipcalc
./bin/touch
./bin/ionice
./bin/lzma
./bin/watch
./bin/pivot_root
./bin/mount
./bin/cmp
./bin/nslookup
./bin/kill
./bin/udevadm
./bin/uname
./bin/fstype
./bin/traceroute
./bin/deallocvt
./bin/ipconfig
./bin/rmdir
./bin/ping
./bin/printf
./bin/tty
./bin/renice
./bin/lzopcat
./bin/seq
./bin/yes
./bin/tar
./bin/awk
./bin/sha256sum
./bin/cal
./bin/kmod
./bin/echo
./bin/df
./bin/egrep
./bin/uncompress
./bin/usleep
./bin/free
./bin/chvt
./bin/hexdump
./bin/cat
./bin/fgrep
./bin/realpath
./bin/ntfs-3g
./bin/mkdir
./bin/mv
./bin/chgrp
./bin/uptime
./bin/tr
./bin/getopt
./bin/chroot
./bin/poweroff
./bin/dmesg
./bin/false
./bin/nc
./bin/ftpget
./bin/timeout
./bin/unexpand
./bin/pwd
./bin/id
./bin/clear
./bin/[[
./bin/netstat
./bin/head
./bin/env
./bin/cut
./bin/du
./bin/basename
./bin/sleep
./bin/mktemp
./bin/zcat
./bin/run-parts
./bin/who
./bin/sort
./bin/bunzip2
./bin/lzcat
./bin/openvt
./bin/expr
./bin/losetup
./bin/dc
./bin/rpm2cpio
./bin/stty
./bin/sha1sum
./bin/xzcat
./bin/find
./bin/microcom
./bin/unlzma
./bin/dumpkmap
./bin/rpm
./bin/mkfifo
./bin/top
./bin/hostname
./bin/mknod
./bin/patch
./bin/last
./bin/whoami
./bin/xargs
./bin/sha512sum
./bin/setkeycodes
./bin/od
./bin/ps
./bin/busybox
./bin/sed
./bin/readlink
./bin/bzcat
./bin/chown
./bin/uuencode
./bin/cttyhack
./bin/date
./bin/unzip
./bin/logger
./bin/ash
./bin/md5sum
./bin/dnsdomainname
./bin/lzop
./bin/wget
./bin/sync
./bin/nfsmount
./bin/ftpput
./bin/[
16359 blocks
+ echo 'Creating uInitrd from '\''volumio.initrd'\'''
Creating uInitrd from 'volumio.initrd'
+ mkimage -A arm -O linux -T ramdisk -C none -a 0 -e 0 -n uInitrd -d /boot/volumio.initrd /boot/volumiord
Image Name: uInitrd
Created: Tue Jul 11 12:14:41 2017
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 4305107 Bytes = 4204.21 kB = 4.11 MB
Load Address: 00000000
Entry Point: 00000000
+ echo 'Cleaning up'
Cleaning up
write board specific boot sector
411+1 records in
411+1 records out
421813 bytes (422 kB, 412 KiB) copied, 0.00264625 s, 159 MB/s
Unmounting Temp devices
==> Orange PI PC device installed
Preparing rootfs base for SquashFS
Creating Volumio SquashFS Temp Dir
Copying Volumio rootfs to Temp Dir
Removing the Kernel
Creating SquashFS, removing any previous one
Parallel mksquashfs: Using 4 processors
Creating 4.0 filesystem on Volumio.sqsh, block size 131072.
[=======================================================================================================================================================================================|] 43568/43568 100%
Exportable Squashfs 4.0 filesystem, gzip compressed, data block size 131072
compressed data, compressed metadata, compressed fragments, compressed xattrs
duplicates are removed
Filesystem size 273410.87 Kbytes (267.00 Mbytes)
33.35% of uncompressed filesystem size (819815.24 Kbytes)
Inode table size 524335 bytes (512.05 Kbytes)
29.89% of uncompressed inode table size (1754131 bytes)
Directory table size 482234 bytes (470.93 Kbytes)
43.25% of uncompressed directory table size (1114915 bytes)
Number of duplicate files found 5880
Number of inodes 52861
Number of files 41971
Number of fragments 2195
Number of symbolic links 3058
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 7832
Number of ids (unique uids + gids) 18
Number of uids 7
root (0)
unknown (1001)
gianni (1000)
avahi-autoipd (110)
systemd-network (101)
systemd-bus-proxy (103)
systemd-timesync (100)
Number of gids 16
root (0)
unknown (1001)
gianni (1000)
shadow (42)
audio (29)
systemd-journal (101)
nogroup (65534)
systemd-timesync (102)
utmp (43)
tty (5)
systemd-resolve (104)
staff (50)
systemd-network (103)
ssl-cert (112)
adm (4)
mail (8)
Squash filesystem created
Cleaning squash environment
Unmounting Temp Devices
Cleaning build environment
