Hi all.
Iam trying to install volumio 2 .
After burning volumio 2 image I am getting
Chipset not compatible please update software.
The pi is pi4 2g.
Now I can boot fine with any version of volumio on pi 4 8g and pi 4 4g.
I then installed pi desktop and tried to update eeprom, it told me it was up to date.
Reason iam using volumio 2 is my adi 2 dac fs and mdac plus are not compatible with versions 4, ie unable to use high bitrates.
Version 3 works fine on All my pi.
So why won’t the pi 2 g except volumio vs 2?
Another thing I found out with volumio 3.
Upnp seems broken.
Mconnect and similar software won’t find any pi. With vs 3
2 works great. Another reason I wanted to stay with volumio 2.
Any chance that it can be fixed?
