After lurking in the forum for several years to gain some experience, this is my first post for support. Hi everyone!
Let me first say thank you to all of the developers that have made such a wonderful application - it has changed the way I listen to music. I cannot speak highly enough about Volumio as it has literally touched the lives (and “ears”) of many friends and family.
A little bit about my problem. I have been running Volumio v1.5 for several years on a Cubox-i4Pro and it has been an absolutely wonderful experience. I mainly use the UPnP capability with a NAS as the music share, and BubbleUPnP as the control point. Volumio v1.5 has been simply flawless.
This weekend I decided to do an upgrade to Volumio v2 with a new micro SD card. The install went fine and after a reboot I had set a static IP address. However, I have found that Volumio does not show up in BubbleUPnP and/or Foobar2000’s UPnP browser. After doing some research in the forum I have found conflicting information regarding whether UPnP is enabled, whether there is an additional plugin required, and/or if UPnP is running by default. After connecting to Volumio through SSH I do see the config files/templates for Upmpdcli in the following locations:
/volumio/app/plugins/audio_interface/upnp/upmpdcli.conf.tmpl
/static/volumio/app/plugins/audio_interface/upnp/upmpdcli.conf.tmpl
I found a post that referenced Volumio 2 and UPnP/Open Home here:
https://volumio.org/forum/how-best-use-volumio-and-upnp-openhome-t5643.html
When I check to see if upmpdcli is running (ps -ax | grep upmpdcli) - I see nothing running. The post from my link above suggests that I should be see something like the following:
$ ps -ax |grep upmpdcli
509 ? Ssl 0:10 /usr/bin/upmpdcli -c /volumio/app/plugins/audio_interface/upnp/upmpdcli.conf
On my installation I just see grep returned:
$ ps -ax | grep upmpdcli
1402 pts/0 S+ 0:00 grep upmpdcli
On my installation MPD appears to be running fine:
$ ps aux | grep mpd
mpd 661 0.0 0.2 124280 11264 ? Ssl Aug26 0:01 /usr/bin/mpd --no-daemon
When I attempt to see the status of Upmpdcli I see the following:
[code]$service upmpdcli status
● upmpdcli.service - UPnP Renderer front-end to MPD
Loaded: loaded (/lib/systemd/system/upmpdcli.service; enabled)
Active: failed (Result: signal) since Sat 2017-08-26 23:21:23 UTC; 1h 40min ago
Process: 931 ExecStart=/usr/bin/upmpdcli -c /volumio/app/plugins/audio_interface/upnp/upmpdcli.conf (code=killed, signal=ABRT)
Main PID: 931 (code=killed, signal=ABRT)
Aug 26 23:21:23 volumio systemd[1]: Started UPnP Renderer front-end to MPD.
Aug 26 23:21:23 volumio volumio[931]: pure virtual method called
Aug 26 23:21:23 volumio volumio[931]: terminate called without an active exception
Aug 26 23:21:23 volumio systemd[1]: upmpdcli.service: main process exited, code=killed, sta…ABRT
Aug 26 23:21:23 volumio systemd[1]: Unit upmpdcli.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.[/code]
Questions:
On Volumio 2 is UPnP enabled by default?
Since I am seeing the config files for Upmpdcli - is this enable by default?
Is there anything that I can do to get UPnP/Upmpdcli working as it was with Volumio v1.5?
Thank you to anyone that can provide some insight/information about my questions - I greatly appreciate it!
