I had the same problem…
First of all thank you volumio team for a nice music player solution. Spotify, webradio, touch display plugin works. Nice ! Except of this “small” annoying “feature” ( not bug
I did fresh flash of volumio, and try lot of times to scan my music collections.
The scanning process hangs up always on same place. After removing the problematic file and his neighbors ( the complete folder), next scan ran trough this point ( number of scanned files), but hangs up on another place ( another song, folder). I have a feeling that this procedure will be some kind of never ending story.
I did next test : I divide my music library into smaller packets ( lots of folders), and add to volumio music library them one by one, as previous group scan successfully finished. In this way I can almost scan all my musics, while loosing only small quantity of data. Finally it looked that there was no more problematic files, which caused error.
After that I remove all mounts, collect my music collections into one “big” network share, and start scan … and the error came back !
So that was the moment when I gave up, and decide to write this post.
I think, it is not on user to find out which file(s) is(are) not compatible with the system, particularly if there are lot of problematic files.
The older version of volumio did not have this issue ( before 2), and MPD scanned correctly the music database on Ubuntu installation.
If the development team need from my side any more information, help or test ( let me do this and this …), do not hesitate to ask me
Here is my configuration :
ODROID C2 with volumio 2016-2.030-volumio flashed onto SD card.
Music collections are on : HP ProLiant MicroServer AMD Athlon™ II Neo N36L Dual-Core Processor
operating system is : nas4free 11.0.0.4 - Sayyadina (3305)
sharing is CIFS/SMB, file system is UFS
Here is the log ( sudo journalctl -f ):
Dec 03 20:46:26 volumio mpd[2581]: update: added NAS/Music_02/Various Artist/Paris Lounge Night/13-robinn-le_mas.flac
Dec 03 20:46:26 volumio mpd[2581]: update: added NAS/Music_02/Various Artist/Paris Lounge Night/04-catharina_josy-autumn_in_paris.flac
Dec 03 20:46:26 volumio mpd[2581]: update: added NAS/Music_02/Various Artist/Paris Lounge Night/01-lemongrass-bonjour.flac
Dec 03 20:46:26 volumio kernel: Unhandled fault: alignment fault (0x92000021) at 0x00000000ee39f926
Dec 03 20:46:26 volumio systemd[1]: mpd.service: main process exited, code=killed, status=7/BUS
Dec 03 20:46:26 volumio systemd[1]: Unit mpd.service entered failed state.
Dec 03 20:46:26 volumio kernel: aiu i2s playback disable
Dec 03 20:46:26 volumio kernel: audio_hw_958_enable 0
Dec 03 20:46:26 volumio systemd[1]: mpd.service holdoff time over, scheduling restart.
Dec 03 20:46:26 volumio systemd[1]: Stopping Music Player Daemon…
Dec 03 20:46:26 volumio systemd[1]: Starting Music Player Daemon…
Dec 03 20:46:26 volumio systemd[1]: Started Music Player Daemon.
Dec 03 20:46:27 volumio mpd[2992]: zeroconf: No global port, disabling zeroconf
Dec 03 20:46:28 volumio volumio[2618]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Dec 03 20:46:28 volumio volumio[2618]: MPD error: Error: This socket has been ended by the other party
Dec 03 20:46:32 volumio volumio[2618]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Dec 03 20:46:32 volumio volumio[2618]: MPD error: Error: This socket has been ended by the other party
Dec 03 20:46:36 volumio volumio[2618]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Dec 03 20:46:36 volumio volumio[2618]: assert.js:85
Dec 03 20:46:36 volumio volumio[2618]: throw new assert.AssertionError({
Dec 03 20:46:36 volumio volumio[2618]: ^
Thank You in foreward for ideas, help and solution,
with best regards, Tot Árpád - Hungary
