Hi
I’ve just noticed that if I try to add another WebRadio or music file from USB to the play queue, it never adds - there is only the current playing song. However, I see the popup (in green) saying that the item was added.
My install is: System version: 0.836 Released: Tue Feb 23 22:29:19 CET 2016
Running on Rpi Model B.
Thanks,
Hadyn
Honestly I can’t really see the difference from the current version 1.55, few beta came out beside a later version raspbian, can’t test dac support, can’t add network location.
By the sound quality, it will not have a big difference, it all depends on the sound chip spec, beagle one version will not come in a short while, so mostly importantly will be feature added and ease for operation.
That’s why I say can’t see much difference, correct me if I m wrong
Sent from my iPad using Tapatalk
Hi , I’m not sure what’s the link between your comment and this post title? H
