The combination of the two makes an AWESOME sounding micro HiFi/Streamer for my small office.
Volumio 1 recognises the Mojo as a DAC but unfortunately Volumio 2 does not.
Is there any extra configuration I can do that will get it recognised. Volumio 2 is getting a lot better and I would like to start using it in my office.
In the user interface under playback options->also options only the ‘bcm2835 ALSA’ device is shown as an option.
Is this correct and should the USB DAC be shown somewhere else? If not can you point me in the right direction to making the USB DAC available and I’ll try and fix it and submit a pull request- just need a push in the right direction.
Yeah, the current code assumes an ordered list of cards - as I have card 0 and then card 5 it never gets up to 5. You should have a pull request by the end of the weekend.
BTW even fixing that issue (which I have done a bit hackily for now) does not actually cause the mpd.conf file to be set with the correct card. I’ll fix that too I hope.
I have Antelope Zodiac Platinum DAC, which has USB audio input, working fine with Windows 10. Volumio 2.041 (and earlier versions) recognizes it, let me set it as an output, but an attempt to play causes “Failed to open audio output” error.
That’s what I have for audio cards and playback devices:
I own a ROTEL RDD-06 USB DAC and can’t seem to make it appear on Volumio. It does not show in the graphic UI under Output Device nor in the terminal when I list output devices:
Sorry, but if it does not get automatically recognized, its not UAC2 compatible… I don’t think there’s anything you can do… Do you know which receiver does it use?
It’s an USB DAC right, so it should show up under “lsusb”, can you post the output of that command? Maybe the device isn’t even recognized and it will need drivers.
Bus 001 Device 004: ID 249c:931c
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
