Where can I get the volume version 2.907? Later versions don’t work well for me. Thanks
Assuming you’re looking for a Raspberry Pi image: https://updates.volumio.org/pi/volumio/2.907/volumio-2.907-2021-07-02-pi.img.zip
Can you give more details about what does not work for you? It may be important if a fix is needed. Thanks
Raspberry 4 + Volumio 2.907 + NAS = OK
Raspberry 4 + Volumio 2.909-17 + NAS = Stops randomly,with DSD files a lot of stops
Raspberry 4 + Volumio 2.917 + (NAS+Media Network+Jriver Media Center 28) = OK perfectly
Thanks!!
Thank you so much
