Volumio 2.513 on tinkerboard with kali reclocker
I have just installed Volumio 2.513 on my Tinkerboard connected with Kali reclocker for a slave DAC.
I find the sound is strange. There are a regular stammer every ~15 sec for either flac or DSD file regardless of its native sampling rate. This did never happen for the previous release befoer 2.5X.
I hope this problem would be fixed soon.
Best wishes,
JH
Could you try this test version
It is a workaround for an I2S clock problem we have with the current Asus kernel, it might be a while before they will be able to fix that permanently.
I’m not sure if that issue also causes your Reclocker problem, but the test version would be worth a try.
