Volumio 2.411 on AppleTV 1st generation
Hi, Why my Apple TV has cuts in the music only when it is in DSD?
If you play DSD from network storage, you can try play locally, but I suppose the problem is the audio card, so I suggest to try a USB dac.
Storage and DAc are by USB with a powered HUB
While you are playing DSD, launch from SSH command #top to view CPU and memory utilization. Maybe the DSD files overload the system.
That’s what I think, I’ll do the test, there’s no way to speed up the Apple tV?
No way to speed up. Try the test, maybe the problem is USB dac. What dac do you use?
top - 12:56:33 up 15 min, 1 user, load average: 0.49, 0.50, 0.40
Tasks: 103 total, 1 running, 65 sleeping, 0 stopped, 0 zombie
%Cpu(s): 12.4 us, 2.5 sy, 0.0 ni, 83.0 id, 2.1 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 240532 total, 236312 used, 4220 free, 8528 buffers
KiB Swap: 524284 total, 20056 used, 504228 free. 76104 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
691 mpd 20 0 154736 20720 1008 S 10.9 8.6 2:17.51 mpd
1017 root 20 0 3368 100 0 S 2.3 0.0 0:32.65 atvclient
32 root 20 0 0 0 0 S 0.3 0.0 0:01.94 kswapd0
997 volumio 20 0 186540 53584 7140 S 0.3 22.3 0:18.68 node
1109 volumio 20 0 97160 3568 2520 S 0.3 1.5 0:03.08 upmpdcli
3105 volumio 20 0 27020 2584 848 S 0.3 1.1 0:01.49 sshd
4811 root 20 0 0 0 0 I 0.3 0.0 0:00.14 kworker/u4:0
4826 volumio 20 0 4860 2196 1852 R 0.3 0.9 0:03.20 top
DAC
tagaharmony.com/en/product/1166/da-300-v-3
Lumio in a laptop HP Compaq NX7400 work fine DSD.
What is this? 8368- ERAAgent 75.7 00:01.17 4 2 43+ 8928K+ 0B 0B 8368 1
this data appears only sometimes and the CPU goes to 80% or more …
CPU usage is low, but the memory is at the limit.
The problem occur with all DSD files?
Have you try to change DSD Playback Mode in audio setting?
Also try reduce Audio Buffer Size.
DSD DirectStream has been implemented in version 2.527, so give me some days to release new ATV porting of the last release.
Yes, all DSD files.
Will it be possible to play .iso files?
Great news, I look forward to the new version.
Great work and thank you very much.
Is the quality of sound with Volumio the same on a PC as on Apple TV?
Hi, Volumio is vers. 2.587…
Please…upgrade, my DSD files not work.
Bad news. My Apple TV doesn’t boot anymore. At the moment I cannot develop a new porting.
Probably I don’t buy a ā€œnewā€ Apple TV, so the project is closed.
Well, it was nice while it lasted.
Thank you so much for everything
Bye
my ipad 1 works well with the apple tv1 however I can not get it to work when I’m with the PC, nor by IP not by Volumio.local ???
For problems not related to Apple TV porting, write in the general section of the forum.
