I’ve downloaded volumio-2.201-2017-06-13-pi.img and I’m sorry to say this, but it does not work well.
I’m using a Raspberry Pi 2 Model B with a Hifiberry Digi+ extension board.
I’ve changed DAC to Hifiberry Digi, restarted and heard the welcome sound, so the sound path works at least. So far so good.
Hardware volume does not work with my hardware (as of my experience from Volumio 1), so I need to select the software mixer to allow volume changes.
I’ve changed to software mixer and saved the setting. Volumio informs about that the mixer has been restarted.
But always when I click (in the playback tab) on a volume less then 100 it jumps back to 100 after some seconds.
After restart the software mixer setting is gone - back to default.
When I didn’t have any USB-Drive or mounted NAS drive, I clicked on library and it didn’t show up. Then clicked on Settings->Network and it didn’t show up either. Had to restart.
Mounting a folder on my NAS drive (WD MyCloud) does not work using NFS.
Sometimes Settings->Network did not show up.
After mounting a folder on my NAS drive, volumio tries to update the music library. It seems so busy or crashed that after some 15-30 seconds the UI is disconnected and in waiting state (round circles moving in the middle).
I had this behaviour also sometimes just clicking around in the menu.
So it’s not stable for me and at the current state not usable at all. It’s a pity.
I had running volumio 1 on this hardware and it was running relatively well. Also had some crashes, e.g. Airplay stopped working sometimes, but it was far more stable.
Is there anybody experiencing the same problems or has somebody and idea what could help?
