The plugin installation stops at 70%, although the message “Plugin Successfully Installed” is displayed;
Same issue with 2.141 and 2.163 releases.
I use PI3+7 inch HDMI Waveshare.
Regards.
Regards.
I’ve tried the same thing, with a Rasp B+ and a 7’’ Waveshare screen. It seems that , by default, the screen is not correctly recognized by the Plugin, which indicates only support of the official 7’’ Raspberry screen, if I’m not mistaken.
I did not have the 70% stopping though (after a fresh install and reflash).
What I did to get it to work :
I Hope it works for you,too;
Nicolas
Thanks.
I forgot to say that install works fine with 2.129 release (up to 100%) with the same hardware config.
For Waveshare 7 inch HDMI LCD ©, I described my setup in a post 1 month ago
waveshare-inch-hdmi-lcd-t6331.html
Maybe is there a bug with newer releases?
Regards.
