Ciao,
since the upgrade to v2.114 I start getting problems with Volumio:
SSH Daemon close connction
this was already exposed, but I’m unclear if there is addressed somehow
Timezone date/time Locale
Seems the upgrade changed my locale information… moving 1 hour ahead
there is no way via UI to set it… I’m supposed to use SSH… but…
WiFi doesn’t recoonect
My WiFi Router (DD-WRT) schedules a reboot everyday at 3.00am
Volumio won’t reconnect to the WiFi… it has to be rebooted
Missing Cron
To fix the upper issue I would like to scehdule a reboot at 6.00am, but cron is not installed
well… I could do it via SSH…
is there a way to backup the library ? (playlist, webradio, favourites…) via UI? I’wouldn’t like to reinstall the image (if it could solve those issues) loosing my preferences
thanks
ciao
M
