Hey, I’ve noticed volumio by default runs an old RPI kernel, it doesn’t contain the driver of a sound card I’m interested in trying volumio with, so I ran the following commands to update the kernel:
sudo apt-get update
sudo apt-get install binutils
sudo rpi-update
sync
sudo reboot
After rebooting, I can no longer ssh or ping the RPI… I used the following build to flash the SD card: volumio-2.041-2016-12-12-pi.img
How to properly update the kernel?
Also how often does volumio update the bundled kernel version?
