The same problem in CSS as before: Volumio 2.029 Menus still not reachable with Android 4,
f.e.g. choosing the first position of a playlist then You see only the bottom frame of the
menu and it will not be centered in the viewport.
Also the field with dots (fa-ellipsis-v) on the right seems to small to touch (Apple says min. 40x40 px). You must try it often
before there is a reaction. With Android 5 You have more success to hit the field.
The sign is only 4px wide plus a little padding and not centered in it´s surrounding.
So on Android 4 most of the toucharea is right outside the view.
