Volumio 1.5: Various errors at boot.
Hey all,
Been using Volumio for a while now decided to update from 1.4BETA on my RPI B unfortunately I get a number of errors on boot :frowning:
I managed to capture a video using one of those cheap ezcap things, below are the screenshots from said video.
error '/etc/init.d/irc' 1: /lib/lsb/init-functions: Syntax error: ")" unexpected error: '/etc/init.d/rc' exited outside the expected code flow.
Cannot execute /bin/bash: Exec format error
If needed I can upload the video somewhere.
I’m now going to reflash the card to see if that helps! :slight_smile:
