Hey,guys
I have a problem with Volumio 1.5
Evereone knows Volumio 1.5 have a problem with MPD port 6600 not listening
the way to solve this problem is change the settings of Playback
but when I change the settings of Playback , a strange situation happend
when I play 16bit music , it is work
but when I play more than 16bit , it will Glitch and Lag (I cant explain but its not normal)
MPD and GMPC work well when I change the setting
Iām try to reflash and Volumio 1.5 is fine when I play 16.24or32bit
but when i change the settings of Playbac , its happing again
Once I change a setting in Playback , it cant be Normal again even I reset the Playback settings!!
Anyone has same problem? or anyone can give me a help? Many thanks!!
