Volumio 1.4 won't play 44.1 files
Hi Michelangelo - thanks for the ongoing work. I enjoy Volumio! And the long nights…
I have 1.4 running on a new Pi and connected via I2S to the ESS9018K2M from DIYINHK. It plays 24/96 and 24/192 files fine but 16/44 files are badly distorted. Seems the sample rate does not change (a guess) when going to a 16/44.1 file.
Is there anything I can try changing in mpd.conf or elsewhere?
By the way, if I play the K2M via USB it works fine with all sample rates.
This is a bug with the driver… If you activate resampling to 96/24 it will fix the issue, but you’ll loose some quality… Take it as a temporary fix, I will investigate on that…
Thanks. Will set re sampling to 96 and wait on next version. Please also set Consume to ‘off’ as default in next version!!!
Keep up the good work…
Yep…
