It is on 192.168.1.69. The music directory is “music_files”.
On my mac that is connected to the NAS, I get this info:
Type: smbfs
Mount Point: /Volumes/Volume_1
Mounted From: //GUEST:@nas1._smb._tcp.local/Volume_1.
How do I translate this info to type into Volumio web UI so that my NAS can be mounted?
Thanks! I am unfamiliar with linux or Unix programming codes. Your advice probably works. I think it involves connecting the cubox-i to a windows based PC using a physical link, installing puTTY and entering commands in the cubox-i to mount the NAS. But I don’t know how to do it. I am more of an audio enthusiast trying to use Volumio, unfortunately for me I am not a hobbyist with programming knowledge.
