Got my brand spanking new dual Udoo and booted Volumio. Nothing. Nowhere obvious on this site is the fact that only Udoo Quad is currently supported. The FAQ tells me I only need a passion with music and neglects to mention I need higher spec’d hardware. Something, maybe a note on the download page would be helpful.
You’re absolutely right. I will make sure to upload a image for Volumio dual. Volumio runs perfectly fine on UDOO dual as well, higher specs are not required. If you wish to use it, you can just flash the UDOO Dual Uboot, and it will boot.
http://www.udoo.org/ProjectsAndTutorials/connecting-via-serial-cable/
http://www.elinux.org/UDOO_creating_a_bootable_Micro_SD_card_from_precompiled_binaries
Same problem but I can’t understand the solution… is there an Iso for a dual UDOO?
