New volumio 3 installation.
Volume jumps every 5 instead of mine setting - 2.
Prerequisites
Volumio Information
Volumio Version: latest 3
Hardware: rpi 3b 4gb
DAC: hifiberry DAC+
DAC: hifiberry DAC+
Hell @misko903
Could be a mixer or step setting. This is what I have for 10 steps.
I think there was a bug that the slider always snaps with step of 5, at least at some point.
It won’t respect the volume step option.
Did you try by pressing + or - instead of moving slider?
Ah, yes that’s it. Slider is always in steps of 5. The custom setting only works when pressing +/-. Never noticed that before.
EDIT: And the setting is labelled correctly: “One Click Volume Steps”
@misko903 You should try the beta app from @Joni_Salminen
