Volume controls
Can someone tell me if it is possible to adjust the volume of each channel separately?
I am looking to use a HiFiBerry Amp (for example) to output mono rather than stereo. I could then use one channel from the amp to power speakers in a room and the other in the garden
Does anyone know if this is possible?
No solution to set volume separately, but, install the plugin FusionDsp:
  • You can set mono output
  • you can set a attenuation for each channel
  • and of course use equaliser…
