Recently I have update my Volumio 2 to version 3.233. This is running on an Audiophonics box with the standard PI 7 inch touchscreen. The soundcard is a hifiberry DAC plus card. The view is the standard classic view (with the 2 circles)
When I was running version 2 I could change the volume. Since the upgrade this is not working anymore as it should be. at 100% the device is playing normally. When I move this to for example 10%, it’s a little bit quieter, but it doesn’t work at the way it should. Is there anybody knows how to change the settings so that this works correctly ?
Many thanks for your help!
Kind regards,
Pieter
